Old 10-10-2019, 08:44 AM
Lotus54 Lotus54 is offline
Default 2019.5- Mac Pro (trashcan) and Mojave
I would like to update my Mac Pro (trashcan) to Mojave. The new Final Cut Pro X requires it and has some things I want.
I use the same machine for ProTools
I currently have High Sierra and the slightly older version of ProTools (18.12)
But I’m having trouble finding out what all I need to update to use the 2019.5 (or .6) of PT.
Do Plug-ins need updates? (I can’t seem to find that info).
Thanks for any help.
Mark
Mark Hollingsworth
Old 10-10-2019, 08:50 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 2019.5- Mac Pro (trashcan) and Mojave
Avid compatibility info here for future reference. You need PT 2019 with Mojave.
Janne
Old 10-10-2019, 08:51 AM
JFreak's Avatar
The ones that come with PT are updated with the PT upgrade. Paid Avid plugins need to be installed separately, you can find the installers from your Avid Account. Any 3rd party plugin you may have need to be checked from the vendor themselves.
Janne
Old 10-10-2019, 08:57 AM
We cannot guess what plugins you have, and what exact versions are installed.
You generally will want to be running the latest plugins from each vendor. So start there.
More importantly however is how you plan on doing, testing, and possibly rolling back from this upgrade. And an in-situ macOS major upgrade is not a good idea. Much better to do a full clean install of Mojave onto a external SSD or spare partition in the internal SSD (if you have enough space to make one). And either way make sure you have a bootable clone image (e.g. using Carbon Copy Cloner, not Time Machine) available on an external drive, and test it boots and works OK before you start.
Old 10-11-2019, 02:34 PM
ramonetl ramonetl is offline
I run it and I had a couple of things early on but I mostly worked it out. I did get cpu crashes occasionally which I have not seen in a long time. The one thing with Mojave is to pay attention to adding things in accessibility. I remember I think you had to do this with mic to get inputs. Forget the exact thing but it was like really why? Just search for it.
2019 iMac i9 + PT 2018 + Mojave rwbreck General Discussion 41 11-22-2019 01:13 PM
GUI issues - 2019.5 and Mojave BrandonUnis Pro Tools 2019 12 06-21-2019 08:42 PM
Mojave Thinks PT 2019.5 is a 32-bit App moogboy100 Pro Tools 2019 3 05-28-2019 09:44 AM
PT 2019 Mojave macPro 5,1 off the wall Pro Tools 2019 20 05-13-2019 06:00 PM
new SSD for PT 2019 and Mojave question. Anibal Pro Tools 2018 0 05-09-2019 09:14 AM
