Old 12-18-2009, 01:19 PM
Patlamm Patlamm is offline
Default Bounce stereo/multiple tracks to mono
Is there a way to take a stereo track, or two mono tracks, and bounce or merge them together without having to bounce in real time? Is there an AudioSuite plugin or command? Thanks.
Old 12-18-2009, 06:26 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Bounce stereo/multiple tracks to mono
Well you could bus your tacks to a New stereo track and record them to one track, but that not what you are looking for. There is no offline bounce in PT.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 12-18-2009, 10:55 PM
albee1952 albee1952 is online now
Sometimes a stereo track is really identical signals on both sides. If this is the case, you can split it to 2 mono tracks and delete one(that can be done in a few seconds).
Old 12-19-2009, 11:11 AM
JonesH JonesH is offline
Sure there is a solution for this. You have to use a plugin that allows for left and right panning such as the Flux Stereo Tool in AudioSuite mode.
Simply pan left and right together and adjust master volume in the plug accordingly so as not to clip. Then process and off you go...
Or you could use peak or wavelab or some other app that's more suited for batch conversions.
I just wanna do engineering...
(as opposed to make music :/ )
Old 12-21-2009, 10:03 AM
Thanks! That did the trick!
(and the plugin is free..)
PT exports stereo interleaved AND multiple mono - why?? jkatcher macOS 5 06-25-2015 04:46 AM
Bounce guitar tracks as mono or stereo? JLEpperson Pro Tools 10 5 07-27-2012 09:12 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
Select multiple mono format to bounce stereo mix? el biciclista Pro Tools TDM Systems (Mac) 19 07-12-2004 04:38 AM
What is the best way to mix for multiple outputs of layback in stereo and mono? Boom Chic Post - Surround - Video 6 06-11-2002 10:56 AM
