Old 11-19-2010, 03:59 AM
alxt alxt is offline
Default 002 as control surface with seperate interface in PT9
Is it possible to use an 002 as a control surface while using another device as the interface (perhaps an Apogee Ensemble or 16x with the firewire card)? I am currently using an iMac that's about two or three years old.
Thanks.
Old 11-19-2010, 07:20 AM
AxeDye AxeDye is offline
Default Re: 002 as control surface with seperate interface in PT9
Command 8 would be the only way i believe, so no. but lets see if someone who owns one can prove me wrong.
Old 11-19-2010, 07:55 AM
I'm going to try with a friends MOTU as soon as my PT9 upgrade makes it to my home. I definitely want to upgrade my interface but would keep the 002 as a control surface if possible....
Thanks
Old 11-20-2010, 07:46 PM
Bump......Has anyone tried this yet?
Still waiting for PT9 to arrive....
Old 11-20-2010, 09:23 PM
HD2 HD2 is offline
Can the 002 be used as a stand alone midi controller like the 003 can? If so then you should be able to still use it as a control surface for PT.
Old 11-20-2010, 09:35 PM
Barry Johns Barry Johns is offline
I would love to ge able to use my 003 as a controller in PT9 with a separate I/O, but you can't.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 11-21-2010, 09:13 AM
HD2 HD2 is offline
According to the 003 set up guide,
"drivers are provided to use the 003 as a Midi control surface on any supported Mac or Windows computer with virtually any compatible software".
Being that Protools can be controlled by other 3rd party midi control surfaces such as a HUI then you could theoretically use the 003 in "Midi mode" using the midi out port 1 or firewire, instead of "protools mode".
If I had another I/O interface I would try this but alas I just have a 003.
Maybe if someone else has the ability and time to try this we could get a definitive answer.
Old 11-21-2010, 10:42 AM
mykhal c's Avatar
mykhal c mykhal c is offline
try it with your computer's onboard sound as PT9's I/O device i've tried to use my 002 controller in this way but was not successful. don't think it has the HUI personality included. seems like you should have success with the 003 controller (accordin' to the manual). good luck with it too.
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 11-29-2010, 05:56 PM
Has anyone been able to use their 002 or 003 as a controller with a separate interface yet?
Thanks
Old 11-30-2010, 11:39 PM
RonB456 RonB456 is offline
003 does not have HUI emulation, so midi mode will not work in ProTools. I've tried to use another interface and use the 003 surface, but it didn't work. so i'm guessing its the same thing for the 002. 003 surface only connects when the interface is selected.
[IMG] code is Off
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
Digi 002 Control Surface as Just an Audio Interface littlegreenmen13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-07-2011 04:53 AM
Will LE users ever get HEAT or a NEW INTERFACE/CONTROL SURFACE??? windsongstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 08-23-2010 06:27 AM
Control surface - MIDI interface Freakybeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-25-2004 04:28 PM
Seperate MIDI interface?? mjames08 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-08-2002 10:37 AM
