Old 07-05-2012, 04:02 PM
2crows's Avatar
2crows 2crows is offline
Default using mulitple displays
hello,
, and thank you for your help,
i am trying to set up PT10.2 on two displays, can i move everything to an alternate display or just the floaters.??
and if so how do i do it.
Old 07-05-2012, 06:32 PM
jeremyroberts jeremyroberts is offline
Default Re: using mulitple displays
Multiple displays is a function of your OS. In MacOS, simply drag your windows where you want 'em. ProTools will remember where your windows are/were and that's that. I personally prefer a single 30" vs. 2 smaller screens as I prefer the horizontal real estate -- but I worked multiple displays for 20 years. Can't imagine not having the pixels. Welcome to the club.
--Jeremy
Old 07-05-2012, 07:14 PM
2crows's Avatar
Jeremy, thanks for posting,
i can drag some of the items , to the 2d monitor but most of them will not, i would like to drag the tracks on one and the mixer onto another and such but
i thought there might be a setting that would allow for that.
Old 07-05-2012, 07:19 PM
RegenerationMix RegenerationMix is offline
the mix window and the edit window can be moved to either display. The plug ins and VI's can also be moved to either display. Not sure what window you cant move.
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
You absolutely can have edit window on one display and mixer window on a 2nd.
Simply drag the windows where you want them.
--Jeremy
Old 07-05-2012, 07:27 PM
gdugan gdugan is offline
That's funny - my brother and I were just having this problem today. He has two monitors, and it seemed we couldn't drag some things onto the other display. We finally figured out that if a window is "maximized" (little green dot in the upper left corner of OSX), the window can't be dragged. But as soon as you make the window smaller (grab the lower right corner and re-size), the window can be moved. Hope this helps.
iMac 3.06 GHz Intel Core i3, OS X 10.8.4, 12 GB RAM, MBox 2 Pro, PT 10 and 11
Old 07-05-2012, 07:28 PM
Benoni's Avatar
Benoni Benoni is offline
for Windows OS you must drag the back gray container box across both(or more) screens if you want the Mix or Edit window to be placed on another monitor. You can already drag plugin windows, transport, stuff like that outside of the container box, but the Mix/Edit stay inside.
http://protoolsquicktips.blogspot.co...eens-with.html
http://www.youtube.com/watch?v=hEEYb-bHrDU
Old 07-06-2012, 12:18 PM
Bob Nagy Bob Nagy is offline
On Windows, my app Skootch is an option.
http://youtu.be/lSITr74hP0I
Contact me directly for more details.
Old 07-06-2012, 01:29 PM
ckreon ckreon is offline
Happy Skootch user here!
- Knowing nothing is better than knowing it all -
Old 07-07-2012, 04:46 AM
paulreed paulreed is offline
I use skootch with 3 monitors on windows....works GREAT
Mulitple Installs ? hwill2008 Pro Tools 9 7 11-06-2010 02:43 PM
How do you set mulitple BPMs on same track? Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-18-2007 08:41 PM
Mulitple identical icons mrmxed Pro Tools TDM Systems (Mac) 9 09-15-2003 01:03 PM
best way to record mulitple tracks?? blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-23-2003 09:42 PM
Mulitple Monitors Doyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-13-2000 11:24 AM
