Protools Free & SMPTE
Can anyone tell me if there is a way to lock an SMPTE based video tape recorder/player to Protools free. Do i need any special midi interface cards or SMPTE-Midi converters? Is there any software solution for this problem?
Re: Protools Free & SMPTE
It sounds like you need a sync box, that converts your SMPTE into MIDI timecode (MTC). The type of box depends on whether you're using vertical interval TC (VITC) or linear TC.
Feed the MTC into a MIDI port. PT Free should lock to incoming MTC when you put it online - small 'clock' on the left of the transport bar. |
Thanks a ton. I'm not very midi savvy. Are there any generic brands that make this, like midiman? how much do they cost?
I don't know what's available in the US, but the cheapest boxes over here in the UK are probably the ones made by Philip Rees. They cost about £99 (around $140?) and can be used with linear time code.
They merge MIDI to allow simultaneous connection of a keyboard with only one MIDI IN port, if you need to do this. All common frame rates are caterd for - 25/drop frame/30 etc. They are not designed to be thrown about, though - a bit fragile! BF |
Outputting SMPTE from ProTools | liebgott | Pro Tools TDM Systems (Mac) | 3 | 09-27-2007 08:04 PM |
ProTools SMPTE Offset | GAttard | Pro Tools TDM Systems (Mac) | 1 | 06-11-2003 06:30 AM |
ProTools and SMPTE problem | Paul Curtiz | General Discussion | 4 | 05-22-2001 08:14 PM |
SMPTE Timecode with PT free | bugsbenny | Digidesign Hardware & Software | 2 | 03-10-2001 03:26 AM |
pismo and protools 4 smpte? | nelmac | Pro Tools TDM Systems (Mac) | 4 | 02-16-2001 02:46 PM |
