Re: -9173 Error HELP
I think an important or at least supicious point is that those CPU spikes followed by those -9173 errors are happening out of nowhere, not while heavy system usage. CPU can be somewhere around 1-2% while playing back a tiny session, an then suddenly it peaks (like on the screenshots).
Plug-ins can cause issues, even when deactivated. Be sure to move them out of the plug-ins folder when testing.
What video cards does each system have and how much VRAM does each have? And, like others have said, have you tried testing after removing every single plugin from your Plugins folder? |
I was suffering a lot from AAE 9173. Also Pro Tools 2018.1 was frustratingly less responsive. Both of these are not happening for almost a month after I took few steps as described below. I tried 3 different fixings one after another. So I'm not sure which fixing particularly worked for my problems (or may be three of them contributed together). Hope these fixes help.
Fix#1:Click 'Windows logo' at the left bottom. Click 'this PC'. Click System drive. Open 'Program Files' folder. Open 'Avid' folder. Open 'Pro Tools' folder. Scrawl down to see 'Pro Tools' Icon. Right click it. Click 'Properties' tab. Click 'Compatibility' tab. In the 'Compatibility Mode' area, uncheck the box 'Run this program in compatibility mode for: Windows 8'. Leave this blank. Also in 'Application' area, check 'Run this program as an administrator'. Hit 'Apply' and 'OK'. Restart the PC. Fix#2:Type control in the search box from 'Start'. Then click 'Control Panel' from the result. Write 'File' in the search box on the top right of the 'Control Panel' window. Then click 'File Explorer Options' from the result. Click 'Clear' to clear 'File Explorer history'. Then click 'Apply' and 'OK'. Fix#3:Go to 'C' drive. Click 'Users'. Click 'user's name'. Right click 'Desktop' and click 'Properties. Click 'Location' tab. Click 'Restore Default' tab, hit 'Apply', hit 'OK'. In addition to these, please trash Pro Tools preferences and database. |
and how will that help the person who made the topic on their two MACS?
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
#16
I have a MacBook Pro mid 2014 and had all these terrible problems.
But after I installed Turbo Boost Switcher I can work normally. Check it out! I installed it and on the menu you can then choose to turn Turbo Boost off. When I do that: no more problems! https://www.rugarciap.com/turbo-boos...cher-for-os-x/ Persen
MacBook Pro M1 (13-inch, 2020) 16 GB RAM PRO TOOLS STUDIO 2022.5 UAD Apollo 8p + Twin Solo + Octo Satellite |
#17
Hi everyone
Thank you for all the hints and tips. I needed a few days to try everything out. Sadly, nothing helped. I deleted all plugins from Plug-Ins folder. I tried the Turbo Boost Switcher. I tried different Interfaces. Currently the iMac runs with only Pro Tools, Avid Application Manager and iLok manager on it (besides Apple standard stuff). Using CoreAudio with the built in speakers. Still getting CPU spikes with -9173 Error following. Graphics iMac: NVIDIA GeForce GTX 675MX 1 GB Graphics MacBook Pro: NVIDIA GeForce GT 750M 2048MB / Intel Iris Pro 1536MB (everything original stock) Any more ideas? |
#18
Solution i go into the file find the (WaveCache.wfm) delete it don't worry when you re-open the session it will return so you have to delete it before working every time |
#19
Solution go in sessions file delete 'WaveCache.wfm' this will have to be done at the beginning of the session every time as it comes back at opening of session this is the only thing that works for me pro tools 12.8 high sierra
#20
one day so far ...
but helps https://www.rugarciap.com/turbo-boos...cher-for-os-x/ thx for the heads Up !!!
Hal Cragin On the DUC Since The Year 2000 AD Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2] |
AAE error -9173 | nikydvt | Pro Tools 12 | 11 | 01-14-2017 04:05 PM |
AAE error -9173 on PT 12.4 | marcnyc | Pro Tools 12 | 2 | 06-24-2016 03:27 PM |
-9173 error in PT 12 | ArKay99 | Pro Tools 12 | 10 | 06-11-2016 01:41 AM |
PT 11 Clearly Not An AAE 9173 Error | rgconrad1 | Pro Tools 11 | 3 | 09-29-2014 11:56 PM |
