PT 2018.1 crash & fix
Has anyone else noticed this situation? I open a session, and when I hit the play button, it's all crackly and low volume with lots of hesitations. So I go to the Playback Engine & change the value to anything other than what it's set to. Close the window, hit the play button, and all is well. I do have Elastic Audio enabled and seem to remember an issue with the playback engine.
Re: PT 2018.1 crash & fix
I have found this happens if you have interface or USB issues but it depends on your system, interface, etc.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
happens from time to time .. and has been happening for quite awhile now .. not exactly sure when this started but Avid has not found a comprehensive solution yet ..
toggling Buffer usually fixes it for me ..
Upgrading from 2018.1 to 2018.3 with Application Manager | lm183902 | Pro Tools 2018 | 2 | 03-19-2018 04:41 PM |
Reverting from 2018.3 to 2018.1 | jamesleonard | Pro Tools 2018 | 11 | 03-12-2018 05:21 AM |
Xpand!2 2018 & Air Instruments 2018 | lgreen100 | Pro Tools 2018 | 16 | 02-15-2018 05:01 PM |
Deleting multiple instances of multichannel instrument presets causes crash in 2018.1 | noiseboyuk | Pro Tools 2018 | 4 | 01-29-2018 06:43 AM |
Installed 32track le version, won't run with Reaktor crash crash crash | Christian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-02-2002 11:05 AM |
