Old 05-22-2013, 11:23 AM
louieshowers louieshowers is offline
Default Re: Alternate techniques for De-Essing
Originally Posted by YYR123 View Post
Nice will check it out
+1
Windows 7 64 Ultimate: SP1
PT 10.3.8
¨WHERE´S MY CHECKBOOK?¨
https://soundcloud.com/louieshowers
Old 05-22-2013, 11:30 AM
Originally Posted by Meads View Post
The SPL DeEsser ist the best I used so far. It's the only one I'm aware, that doesn't get triggered by volume but by waveform. It detects the "s" frequency and attenuates it via phase cancellation.
I always had the issue with stuff like Waves Deesser and the like, that once somebody is screaming or vocals get very loud the Deesser kicked in very harshly even though there wasn't even an "s", making the vocal very dull.
Don't have that issue anymore. Highly recommend the SPL Desser.
thanks .. You are correct about the volume triggering..in those cases I would use automation on the threshold for those instances of screaming. Increase the threshold to provide less reduction during screams...But I am definitely going to check out the SPL Deesser. Sounds awesome. Thanks!
PT 10.3.8
Old 05-22-2013, 11:37 AM
Meads's Avatar
Meads Meads is offline
Of course. That's how I used to do it. But I found that very annoying.
Now with the SPL, it's just one thing less to worry about.
This is one of the rare plugins I would not ever want to miss or have to replace any more.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24
Old 05-22-2013, 12:37 PM
YYR123's Avatar
YYR123 YYR123 is online now
And those guys are already AAX correct?
Daniel
Old 05-22-2013, 12:38 PM
Meads's Avatar
Yes. They also have ported some to AAX DSP. Not the DeEsser, though.
iMac Pro
- MacOS 10.14.6
- C|24
Old 05-23-2013, 12:06 PM
BohoProAudio BohoProAudio is offline
So, no fans of pass filter bus compression here? I think it offers more flexibility than using a single purpose de-esser.
Old 05-23-2013, 12:52 PM
could you explain?
PT 10.3.8
Old 05-23-2013, 06:45 PM
First, send the vocal track to two mono aux tracks. One will be hi pass, one will be lo pass. Find a bad ess region to fix. Put a pass filter on the lo pass which rolls off the sibilance frequency. Process that aux as you normally would on the vox. On the hi pass aux, put a pass filter at the same crossover point, to get rid of the lows so you can apply a more aggressive compression ratio to keep the air without cutting heads off. Then send both to another aux and mix to taste.
Old 05-25-2013, 06:33 AM
janmuths janmuths is offline
Instead of de-esser plug ins, I now use clip gain. Takes a moment, but sounds superior to all plug ins I've ever used (at least to my ears).
2010 Dolphin Award for Production / Engineering
AVID Certified Instructor
Old 06-20-2013, 11:32 PM
Guy McDude Guy McDude is offline
agreed.
Also a great fix for finger/ fretting noise on acoustic tracks.
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
www.seanmcdonald.com
De-Essing......where in the chain? jlcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 07-27-2013 08:45 AM
De-essing Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-21-2004 09:34 AM
De-essing Vocals skylab001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2004 01:11 PM
Hand de-essing tips please! Jules Tips & Tricks 21 04-02-2003 01:52 AM
De-essing With Digi???? sugarfuzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-25-2002 11:17 AM
