Old 11-06-2023, 09:12 AM
XNA XNA is offline
Default ProTools v2023.9.0 Freezes on launch
I purchased a new MacBook Pro M2 Max OS14.1 a month ago. I set everything up, installed PT and it seemed to open fine and work. But now, when I try to open PT v 2023.9.0 it always freezes up on the launch window and never opens. Attached is a screenshot of the frozen screen.
File Type: jpg Screenshot 2023-11-06 at 9.02.45 AM.jpg (30.9 KB, 0 views)
Old 11-06-2023, 09:47 AM
sw rec sw rec is offline
Default Re: ProTools v2023.9.0 Freezes on launch
More details about your computer/setup would certainly help here.
Nothing has been “officially qualified” with Sonoma yet, but some report it’s working fine.
Check here and see if you’re in “not compatible” territory.
https://avidtech.my.salesforce-sites...tibility-Chart
Old 11-06-2023, 10:05 AM
The first thing to suspect are non Apple Silicon compatible plugins. Unfortunately there are still some that have not been updated to be compatible yet. You'll need to check each manufacturer to see if they have a compatibility statement and what version is needed. In the short term, you can try to run Protools in "Rosetta" mode to see if those plugins work that way.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 11-06-2023, 10:14 AM
marianna's Avatar
marianna marianna is offline
Hi there
Looks like the launch process is stopping at Mod Delay_III which might be incompatible with Sonoma. Go to the plugins folder and see if dragging that to the desktop allows the PT app to launch.
As was stated - you might need to update some plug in's.
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
Old 11-06-2023, 10:17 AM
XNA XNA is offline
How do I run it in "rosetta mode"?
MacBook Pro 16in M2 Max 2023
32gb RAM
2TB SSD
-Running-
Pro Tools: Studio 2023.9.0
Old 11-06-2023, 10:20 AM
XNA XNA is offline
Originally Posted by marianna View Post
Hi there
Marianna
Where do I find the plug in folder?
32gb RAM
2TB SSD
-Running-
Old 11-06-2023, 10:57 AM
marianna's Avatar
Are you on Mac or PC.....? instructions depend on OS. I see your on a Mac based on your profile. This is something that you can easily google.
Instructions are here on our Knowledge Base.
https://avidtech.my.salesforce-sites...older-location
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
Old 11-06-2023, 02:40 PM
XNA XNA is offline
Marianna
yes, I am on the Mac that is shown in my signature.
I followed the path in the link you provided....there is not "Audio" folder within the "Avid" Folder.
I've googled it and some people say to look in the Library>Application Support>Digidesign>PlugIn. But there is no "Plug in" folder within "Digidesign".
32gb RAM
2TB SSD
-Running-
Old 11-06-2023, 03:58 PM
marianna's Avatar
what Mac OS exactly are you on? version please?
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
Old 11-06-2023, 04:30 PM
No, anything with Digidesign is ancient and wrong. The modern AAX plugin folder for all versions of Pro Tools for the last decade or so is
/Library/Application Support/Avid/Audio/Plug-Ins
or
/Library/Application\ Support/Avid/Audio/Plug-Ins
if you are typing this in the Terminal/shell and need to escape the space in Application Support.
If there is no Audio directory in the Avid directory then something is very wrong with your system. And more than that I'd say that's impossible given that when Pro Tools starts up it will automatically recreate that directory and add the default core plugins to the Plug-Ins folder within it. So you are almost certainly looking at this wrong.
One guess is you are looking at
~/Library/Application\ Support/Avid
or
if you are already in your home directory.
Instead of
Pro Tools v2023.6 Now Available Avid Technical Alerts 0 06-08-2023 10:22 AM
Pro Tools v2023.3 Now Available Avid Technical Alerts 0 03-24-2023 09:12 AM
Protools 10.3.4 freezes computer on launch SevenFactor macOS 1 12-11-2013 10:51 PM
Protools 8 Freezes at "Creating Dae Objects" upon Launch? MythMuzik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 04-22-2011 07:53 PM
6.1 freezes on launch TomSmith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-22-2004 07:20 PM
