copying automation in controller lanes
Hello,
I have automation occurring in: Controller Lane Mod Wheel (1) and I have Vacuum instantiated. In Vacuum I have called up: LPF Cutoff - and the 'green light' shows it is active. I want to copy the automation from: Mod Wheel (1) and apply it to: LPF Cutoff. I have tried:Copy> To Current Automation Type - but this command will not apply the Automation to the Controller Lane (LPF Cutoff). What command am I forgetting? (btw, I have tried everything. i.e.: Copy Special> All Automation, Pan Automation, Plug-in Automation - as well as Paste Special> Merge, Repeat To Fill Section and to Current Automation Type). For example: When I: Copy> To Current Automation Type - from Mod Wheel (1) to Pitch Bend - the automation will copy |
Re: copying automation in controller lanes
You are trying to copy MIDI controller data to audio automation lanes. LPF is automation not MIDI CC data. Mod wheel is MIDI CC. Pitch Bend is MIDI data.
That isn't allowed. That isn't the same thing as copying to automation lane type. If you are unclear on what is MIDI data and what is automation, Pro Tools separates the categories in the drop down list for lanes. (on top of which, in parenthesis the CC number is written for CC data) |
Oh thats easy to sort out... I thought you could apply the data (drawings, triangles, squares, etc.) to midi cc numbers.
thanks For those of you interested: Sound Control #6 (75) - (LPF C/O - Vacuum) Last edited by jamesleonard; 02-18-2018 at 07:56 AM. |
Hide automation lanes? [solved] | dg27 | Pro Tools 11 | 6 | 03-14-2023 11:39 AM |
Naming Automation Lanes | DonaldM | Pro Tools 11 | 2 | 09-22-2014 10:32 AM |
Loosing Controller Lanes in MIDI Editor | chuckgreenjr | macOS | 0 | 11-02-2012 03:42 PM |
Different controller lanes for each channel | Polarbear066 | Pro Tools 10 | 2 | 10-17-2012 03:32 AM |
Controller, and Automation lanes. | JimC | Pro Tools TDM Systems (Mac) | 12 | 05-25-2010 08:28 PM |
