Old 02-17-2018, 12:08 PM
Kiwiflip Kiwiflip is offline
Default Pro Tools is unable to communicate with HUI
I've searched for some tips regarding this error message, but I don't really understand what it means.
I just installed Pro Tools 2018.1 on my MacBook Pro (MacOS High Sierra 10.13.3), and I am trying to set up my Yamaha Reface DX synth as a MIDI controller (I have been using this on my Windows 7 PC with Pro Tools 12, without any problems). I added it under Peripherals as HUI, chose Reface DX under "receive from" and "send to", and Reface DX is checked under MIDI Input Devices.
I get the "Pro Tools is unable to communicate with HUI" error message, and nothing happens when I press the keys (though the speakers on the synth stop playing once it's connected, which hasn't happened before, I assume that's because it recognizes that it's being used as a MIDI controller).
Any ideas?
Old 02-17-2018, 12:10 PM
john1192 john1192 is offline
Default Re: Pro Tools is unable to communicate with HUI
Any ideas?
hi, do you have 2 midi cables plugged in or just one ???
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-17-2018, 12:13 PM
I am using a USB cable (this is what I've been using on my PC as well).
Old 02-17-2018, 01:48 PM
BScout BScout is offline
Any ideas?
The Reface DX isn't a HUI controller. HUI controllers are generally mixers. Turn all that off in Peripherals.
You just need to set it as a MIDI input device.
Old 02-17-2018, 03:57 PM
Thanks for the suggestion. I removed it from peripherals, but it still doesn't work. Also, I've been using it on my Windows 7 PC with no problems, and it was set up in peripherals there(?).
Tried using it in GarageBand, and it worked immediately, didn't need to set up anything...
Old 02-17-2018, 04:41 PM
Can you post screenshots of your settings for:
Setup>MIDI>MIDI Input Devices
Setup>MIDI>MIDI Input Filters
Old 02-17-2018, 06:19 PM
Old 02-17-2018, 06:29 PM
OK USB understood, just curious ... are there any drivers for it that need to be or can be loaded ?? and i have read where you say it works fine with GB ..
how does it look in AMS ??
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-17-2018, 06:42 PM
I'm not aware of any downloadable drivers, and it worked fine in Pro Tools on Windows and GarageBand on my MacBook without installing anything...
I don't really know what the settings in AMS do, but I am attaching a screenshot.
Old 02-17-2018, 07:02 PM
there is a MIDI window .. sorry i should have been more specific
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Pro Tools unable to communicate with HUI MCU. earshatter Pro Tools M-Powered (Mac) 2 11-17-2016 12:56 AM
Pro Tools Unable to Communicate with HUI Cosmic_Ocean Pro Tools 12 7 08-14-2016 12:07 AM
Pro Tools is unable to communicate with HUI. thingfish_mpowered Pro Tools M-Powered (Mac) 17 01-29-2016 04:18 PM
Pro Tools is unable to communicate with HUI milkman Pro Tools M-Powered (Win) 4 05-20-2008 02:27 PM
Pro Tools is unable to communicate with HUI Gilfigga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 09-22-2003 06:57 PM
