Old 02-15-2018, 04:40 PM
GTBannah GTBannah is offline
Default Paste To Location, Not To Area.
Hello!
Why is it, that I can't paste to a location? Why do I have to select an area, before I paste?
I would like to be able to copy bars three and five, then paste them to bars nine and ten; between bars nine and eleven. Why do I have to select the area? Why can't I just put the cursor at bar nine, Cmd-V, BOOM! and move on?
What am I missing?
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 02-15-2018, 04:46 PM
john1192 john1192 is offline
Default Re: Paste To Location, Not To Area.
Originally Posted by GTBannah View Post
Hello!
What am I missing?
Spot Mode is one solution .. and i think there is a key command to place cursor at say bar 9 and then select what you wish to go there, .. but have to play with it unless someone knows right away .. standby having a beer and some pizza ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-15-2018, 04:48 PM
so, if you put your cursor at bar Nine, and you already have your 2 bars cut & selected .. then just hold the Control key and click on the Clip .. Bam moves to Bat Nine
is this what you are looking for ???
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-15-2018, 04:56 PM
That's nice, if you're "cutting", even though, you'd have to move back and forth.
What I'm talking about is "copying", where you select bars three and four, Cmd-C, move the cursor to bar nine, Cmd-V, new material pasted at bar nine.
As it is now, I have to select bars nine and ten, then Cmd-V, or else nothing is pasted.
Derrkins
GuyBarTola
Old 02-15-2018, 04:58 PM
then use Spot MOde ... bars three and four .. option Click in Spot MOde and it will Copy and Spot at the same time ..
maybe this is what you need
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-15-2018, 05:20 PM
Thanx, for the suggestions, but, I think I'll continue selecting the area. Spot Mode takes longer.
Sonar, Sequoia, Nuendo .... they all operate the way Craig Anderton described sequencers, like musical word processors.
Select area, Ctrl-C, place cursor at new location, Ctrl-V, BOOM! Next?
Derrkins
GuyBarTola
Old 02-15-2018, 05:28 PM
Drew Mazurek's Avatar
Hello!
What am I missing?
Not sure I follow. I do what you're describing all the time. What's in the clipboard gets pasted over what's there. Or if you're in Shuffle mode it gets inserted at the cursor and pushes everything else down the timeline.
You do have to make sure the cursor in on the same tracks that what you want to paste came from. For example, if I select 2 bars across 3 tracks and hit copy, I need to put the cursor at the bar position I want to paste them to on the same 3 tracks.
Make sense?
See gif.
www.drewmazurek.com
Old 02-15-2018, 05:32 PM
thats does not seem what you asked .. this is straight copy and paste !!! and it works perfectly .. where did i mistake what you meant !!!
you said "Why do I have to select an area, before I paste?" when above you clearly say "Select area, Ctrl-C, place cursor at new location, Ctrl-V, BOOM! Next"
i am happy you are sorted but that was confusing ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-15-2018, 05:41 PM
I'm saying how it works in the three applications I mentioned, and, that this is how I'm hoping to do it in Pro Tools.
Derrkins
GuyBarTola
Old 02-15-2018, 05:45 PM
ahhh .. that is how it works .. Select Section you wish to Copy .. CMD-C and the put your cursor where you wish to Paste and hit CMD-V ..
you can do exactly as you asked .. select bars 3-5, copy them CMD-C, the place your cursor at bar 9 and hit Paste CMD-V ..
you do not need to select bars 9-11 ..
am i still missing this ???
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Copy... Paste... Paste... Paste...? accession 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-18-2022 04:18 PM
Can you "Paste to original location" for MIDI studioj11 Pro Tools 11 8 09-24-2013 02:28 PM
Copied region length auto-adjust to paste location length? greglawrence Tips & Tricks 4 10-23-2011 12:46 PM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
Copy all from location to location question! crizdee Pro Tools TDM Systems (Mac) 3 11-29-2005 04:27 PM
