Re: Issues running PT 12.x and 2018 on Late 2012 i7 iMac 27" 3.4Ghz 32GB Ram
As long as the fusion drive works reliably with the app, VIs & samples then that would be absolutely great. What I really want to know is if this particularly model has any inherent problems from its design like what I have experienced with the GPU overheating issue on my late 2011 Macbook Pro. Much thanks for you help musicman691
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard https://soundcloud.com/2b3productions |
i just run it fw800 to fw800......easy breezy.....mine has regular 7500 rpm system drive, and 7500 rpm fw drive
www.kfaudio.ca |
I think you mean TB-FW800 and 7200RPM drive. The latter was easy enough to understand, but the former needs clarification as his machine has no FW ports. The TB-FW adapters work fine, even when going down to FW400. Done it on a few different Macs over the years with different interfaces and they e all worked as they should. Sent from my iPhone using Tapatalk |
I thought that is what he meant
#16
Before the Native Access installer for NI Komplete, the service center installer did not give the option to decide the location for its content. My third party Kontakt libraries like String Essentials, Classical Collection & Vintage Horns do not give the option to specify location as well as Logic Pro X content.....but it is only some stuff. I totally agree with you to swap out the FD for a SSD but I'm not sure (still trying to find out) if the late 2012 iMacs use Sata III connectivity internally so it it may not be possible. I've read that SSD part of the FD is soldered to the logic board.
#17
I am running 2018 on High Sierra without any issues.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
#18
#19
#20
Not all NI installers allow you to specify the content location and my third party installers did not, I agree you can move the content & when you launch Kontakt it shows content missing where you then point its 'locate content' window to the path where it is kept. Logic Pro X does not allow you to specify where it stores that content. Your link is broken: 404 not found.
Imac late 2012 upgrade or not? | hakofred | Pro Tools 12 | 9 | 12-27-2017 01:38 AM |
SSD Upgrade for iMac i7 (Late 2012) | Prosound | Pro Tools 11 | 5 | 03-24-2017 01:42 PM |
iMac Late 2012 and Pro Tools 11 questions | hermantf | Pro Tools 11 | 8 | 02-11-2016 07:06 PM |
32GB DDR3-1600 OWC memory for 2012/2013 Imac | John_Toolbox | Buy & Sell | 1 | 05-13-2014 05:18 AM |
PT11 with iMac (Late 2012) and Fusion Drive | Rohrak | Pro Tools 11 | 7 | 03-31-2014 06:32 PM |
