Old 03-01-2016, 07:46 AM
Default Re: Phantom power is on but no sound levels
The C214 is a condenser and does need phantom power. I suggest the OP spend some time on youtube and search for videos such as:
Getting started with pro tools
Basic recording with pro tools, how to record in pro tools
Those kind of videos will help a lot more than us typing advice here(a picture is worth a thousand word, and a video is worth..................)
Old 03-01-2016, 07:22 PM
wwittman wwittman is offline
Originally Posted by musicman691 View Post
That is wrong; you never want to use phantom power on a non-active ribbon mic or dynamic mic.
no you're wrong
in the actual world, pro recording studios have had phantom on every console channel, on all the time, going back basically for as long s phantom power has existed.
with correctly wired mics and xlr, it's a total non-issue
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Old 03-01-2016, 08:52 PM
Originally Posted by wwittman View Post
no you're wrong
Until somebody blows up a vintage ribbon mic and furniture starts getting thrown at walls/people.... but hopefully folks who have those mics know how to handle them. For the typical beginner at home it maybe makes little difference what they do as default. As long as they know which of their microphones absolutely need phantom power and they need to be careful knowing there is power on leads/boards if they are connecting different things. It may not matter but I expect the best approach for many folks, with typical small studios and uh "creative wiring", may be to start with phantom power off unless needed.
None of this is helping the O.P. with his issues... come on back were here to help...
Old 03-02-2016, 04:34 AM
Bookerv12 Bookerv12 is offline
More and more, mostly starting over the last year or so, I go over to trouble shoot bad setups and the owner has a fundamental misunderstanding of phantom power...
Recently I have started to hear, "of course the phantom is on; I'm using XLR's to hook up my gear."
It's a good thing to actually sit them down and explain how it works.
There is a ton of mis-info online.
Generally, someone who doesn't understand how to hook stuff up is not going to even have access to a super old ribbon that is sensitive to phantom anyway.
They will break it some other way.
But yes...
Back to the problem.
bookerv12
Old 03-02-2016, 04:52 AM
Like give it to a vocalist that's given to screaming. My favorite story on how to break a ribbon is one Rob Halford of Judas Priest tells about how he killed a ribbon mic by doing his usual vocalizations into it.
Jack
QAPLA!
  #16
Old 03-02-2016, 07:35 AM
StefB's Avatar
StefB StefB is offline
Originally Posted by A1 View Post
You need to learn the basics of recording chain 101... You're not even familiar with DAWs?... That is like a toddler looking for the best running shoes available...
Help the OP or shut up - You are not helpful or even funny - just nasty - I wish the Duc from 16 years ago will resurface without all this smart alec comments
Mac 16 Core 7,1 -Os 10.15.7 - 96 gb Ram - Pro Tools 2022.6 Ultimate in 5 suites - MTRX Studio -S6 26-5-D - Sync HD - Video Satelite (Symphony 2022.5, AJA Kona 3g) Pro Protools 2022.6 Vanilla in 21 x Recording and Edit suites. Mac 6,1 Mac Mini, Mac Mini M1, Mac Studio Pro, Mac Studio Max
Mediacomposer 2021.12 on AJA Kona 3g / XT I/O x 3 suites. Multiple Avid S1, S3 & Docks
  #17
Old 03-02-2016, 07:40 AM
StefB's Avatar
OP
Ity seems that you are monitoring straight in and out of your interface, without the audio reaching protools. Make sure you have the drivers installed if that is applicable and check your playback engine under Setup Menu. You should see your interface there - or it should be protools aggregate setup in the Audio Midi Studio software. The next place to go is your I/O setup.
recording with phantom power *and* without phantom power simultaneously SweetSoulSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-22-2008 07:40 PM
phantom power sound off Xone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-25-2006 06:32 PM
Phantom power problems and recording levels jons 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-10-2004 08:07 AM
MBox Phantom power kills sound in 6.22 itsallinthebook 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-28-2003 01:52 PM
Digi 001-No phantom power or monitor sound! MarkBuraglio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-27-2002 05:19 AM
