undo jump to session start after accidentally pressing enter
Sometimes I press unwanted enter (return) and the playhead jumps to session start. That can be annoying especially, when i work on a long session, because it takes time to find back to where i was.
When this happens, I hold down the option-key (alt) and click into the middle of the zoom-cross (the middle between the four buttons for zoom audio/midi on the top left) - then the view jumps back to where I was before. This only works, when I did not press play in between (and: the playhead stays at session start, so you have to click into the timeline also). Does anybody else uses that shortcut, or knows why that works ? It can be used to minimize the bad effects of the socalled scrollbug (PT does not scroll, if the incoming TC is lower than the playheads position) in PT 6.4 and 6.9:Usually the scroll bug only occurs after editing (talking about movie postpro), because then the incoming timecode will be lower than the playheads position, when you listen to the piece you just edited (you edit, then you rewind to a position earlier and playback again). To avoid that, simply press enter (return) after editing and hold option while clicking into the zoom-cross. The view jumps to the position you just worked at and PT scrolls as soon as it is locked.(I think this is much better than working with a fix playhead) |
Re: undo jump to session start after accidentally pressing enter
Hi folks,
could at least anybody confirm, that this is working and that this is at least a little bit odd ? thanks, says the surfer |
I have no idea if this was programmed intetionally or if it´s just a "bug" that functions as a feature some times. But I use it all the time when the cursor jumps to some location lightyears beyond my viewed time-line. You just have to make sure that you click into the time-line once the location comes back otherwise if you press play right away PT will still play from session start and the trick won´t work a second time. Frank. |
Pressing space bar does not start palyback. PT 7.3.1 issue | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-14-2007 10:18 PM |
Pressing down arrow moves cursor to start | guitarmongoose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-05-2005 09:47 AM |
Jump start PT 6.7? | s0nguy | Pro Tools TDM Systems (Win) | 1 | 01-11-2005 11:06 AM |
Jump start my life | spacemanmatt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 12-21-2004 06:57 AM |
audio start times jump around | baker2re | Digidesign Hardware & Software | 2 | 02-22-2002 01:50 PM |
