Mute automation
Hi all,
Something that's bugged me for a long time: I never use mute automation, and have it disabled in the auto-enable window. So, how come, if I just want to mute a track while I'm working, it immediately un-mutes itself as soon as I start playback? Thanks in advance! Joe |
Re: Mute automation
check and see if there is an automation dot keeping it in the on position if it is still visible
i don't use the disable you did but i have had a mute not work and found that i had put a dot on the function that was on in the backgroud check and see.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Re: Mute automation
if you have mute disabled in the automation window, you won't write new mute data. but you'll still play back existing mute data. you may have had mute enabled earlier -- if so, even writing just one pass of automation would have created breakpoints.
you can easily remove spurious breakpoints by choosing mute track view on all tracks, selecting the entire session, and clearing the breakpoints. or you could choose mute track view on any track and command-option-click on that track view button to disable reading and writing mute information on all tracks. |
Re: Mute automation
Peace, Brandon
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Re: Mute automation
Hey, thanks so much for the great tips everyone, and the great trick Brandon!
I'll bet there's a mute breakpoint in the tracks from when I first created the mix template, and I'd imagine that any OMF tracks I get probably have an automatic "Mute Off" breakpoint at the top. Sigh, one more thing to check..... Looking forward to less profanity today |
Mute automation bug | [email protected] | macOS | 7 | 08-14-2011 04:04 PM |
Mute automation | mcgirr | Tips & Tricks | 19 | 01-29-2009 06:07 AM |
Mute Region or Mute Automation | Jeremy Mix3000 | Pro Tools TDM Systems (Mac) | 9 | 01-22-2007 07:53 PM |
7.x mute automation | Scott Sumner | Pro Tools TDM Systems (Mac) | 0 | 07-25-2006 01:49 PM |
mute automation | mik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-01-2004 03:38 AM |
