Old 10-23-2006, 08:03 AM
Karl Engel Karl Engel is offline
Default Save Audiosuite Gain settings
Is there a way to save Audiosuite Gain settings? Like say I want Gain to pop up with a +3dB setting, instead of having to move the slider each time. Is there some other quick way to do regular volume changes by preset amounts?
Old 10-23-2006, 08:09 AM
Kryst Kryst is offline
Default Re: Save Audiosuite Gain settings
Not sure... but once you move it once and process one region, you can keep it open and select other regions, and process them as well. (In case you haven't noticed).
If it's per project, and not per region that you're really inquiring about, I'm not sure. But if you figure out all the regions you want to add gain to before opening it from the Audio Suite, the above suggestion I've made could atleast speed things up for you.
Kryst
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Cannot save plug-in settings to Root Settings folder SimonORorke Pro Tools M-Powered (Win) 1 01-18-2008 08:38 PM
7.3 "Save as to 6.4.1" gain settings bug ? TommyT Pro Tools TDM Systems (Mac) 0 12-15-2006 11:49 AM
Gain from audiosuite Bodhisan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-24-2003 10:44 AM
audiosuite gain?? legativity Pro Tools TDM Systems (Mac) 2 06-13-2001 11:02 AM
