  #21
Old 02-16-2018, 06:40 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Issues running PT 12.x and 2018 on Late 2012 i7 iMac 27" 3.4Ghz 32GB Ram
Well whatever it is, NI is so lame for not making offline installers available
So very lame.....like the kind of lame that would have went to work instead of Woodstock.
Daniel
  #22
Old 02-17-2018, 05:13 AM
Originally Posted by foxes View Post
Ni service center does not allow you to specify the content location, it only allows you to specify where installation files will be downloaded to: https://support.native-instruments.c...ervice-Center-
Not all NI installers allow you to specify the content location and my third party installers did not, I agree you can move the content & when you launch Kontakt it shows content missing where you then point its 'locate content' window to the path where it is kept. Logic Pro X does not allow you to specify where it stores that content.
Your link is broken: 404 not found.
Apologies for the broken link; it used to work. Anyway here's the corrected one: https://support.native-instruments.c...cles/210263925 which is for OSX 10.9.x and lower. Here's one for OSX 10.10.x and higher https://support.native-instruments.c...s/115005719829
Once again - if you pay attention during the install you can tell the installer where to put the content. Many people miss that and in any case many people also don't use the service center to do an actual first install. I don't care about Logic's inability to put sample content where you want. It's strictly up to the third party developer to wrangle with that.
  #23
Old 02-17-2018, 05:16 AM
You actually don't need to be online for an install; you just need to be online to download and authorize the install. Once you have the file(s) downloaded & authorized you can pull the plug on the 'net. I keep all my installers saved of to a hard drive in case I need to reinstall something and for NI I don't need to go online to do that.
  #24
Old 02-17-2018, 11:03 PM
elicious elicious is offline
Hi foxes, back to your original post,
and also to echo Eric from earlier in the thread;
I am running basically the identical machine in the home studio,
with an internal spinner,
and multiple libraries on external FW's through a Nitro A/V hub
and can handle very large sessions and other multitasking very smoothly.
ihatetyping
  #25
Old 02-18-2018, 11:34 AM
foxes's Avatar
foxes foxes is offline
Thanks, my third party libraries definitely did not give that option on installation.
Apple can be right pain in the groin at times.....lol
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
  #26
Old 02-18-2018, 11:37 AM
foxes's Avatar
I too keep all my installers and all Apple OS versions archived on separate drives, best practise indeed.
  #27
Old 02-18-2018, 11:44 AM
foxes's Avatar
Hi elicious,
Yes my initial reason for this thread.....lol
Much thanks for your feedback, glad to know
Imac late 2012 upgrade or not? hakofred Pro Tools 12 9 12-27-2017 01:38 AM
SSD Upgrade for iMac i7 (Late 2012) Prosound Pro Tools 11 5 03-24-2017 01:42 PM
iMac Late 2012 and Pro Tools 11 questions hermantf Pro Tools 11 8 02-11-2016 07:06 PM
32GB DDR3-1600 OWC memory for 2012/2013 Imac John_Toolbox Buy & Sell 1 05-13-2014 05:18 AM
PT11 with iMac (Late 2012) and Fusion Drive Rohrak Pro Tools 11 7 03-31-2014 06:32 PM
