Old 12-06-2016, 03:30 PM
littlesicily littlesicily is offline
Default S3 not working in Sierra
I just did a clean install of OS X 10.12.1 on a fresh drive, used migration assistant to copy user data and my S3 will not work properly.
I keep getting the error " The network address of this unit appears to be set incorrectly".
I can boot up my Mac on my old system HD 10.9.5 and the S3 works fine. Not changing anything else.
I've uninstalled and reinstalled the EuControl software several times, still no luck.
Any ideas?
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1
Old 12-06-2016, 03:41 PM
mattrixx mattrixx is offline
Default Re: S3 not working in Sierra
Not particularly helpful, but mine is working great with OSX 10.12.1 and PTHD 12.6.1
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 12-06-2016, 03:47 PM
Did you also migrate your network and other user settings from an older OS?
Old 12-06-2016, 03:54 PM
Yes, I just upgraded from Mavericks....to Yosemite...ElCap, then Sierra.
I've never done the clean install and re-install everything path. Takes too long and I've never had any issues. (just always Carbon Copy Cloned prior, so I have a safety net of sorts).
I just use the second ethernet port on my MacPro for the S3 an Transport (through a cheap gigabit switch as I don't use the AVB). Using DHCP and it just works.
Matt McKenzie-Smith
mattrixx.net
Old 12-06-2016, 03:57 PM
I was told not to connect the S3 directly to the Mac Pro (unless using a coupler/crossover) so I have my S3 connected to an ethernet hub. Works fine that way in Mavericks and 12.5.2. Bet then I boot up in Sierra and I get the IP error. I'm also using DHCP.
Old 12-06-2016, 04:01 PM
Before I got the Transport I had my S3 connected directly ( didn't require a crossover cable). Worked just fine.
Matt McKenzie-Smith
mattrixx.net
Old 12-06-2016, 04:03 PM
Ok, thanks for the info Matt. I just ordered a crossover coupler and will try that, just in case, on Thursday when it arrives.
Seems like a software issue but I just don't know what it might be.
Old 12-06-2016, 04:51 PM
Have you updated Eucon and the firmware in the S3?
Matt McKenzie-Smith
mattrixx.net
Old 12-06-2016, 06:42 PM
Yes I did both and even reinstalled software. Restart. Etc.
Mbox Pro 3 not working with MacOS Sierra Focuret FireWire & USB Audio Interfaces (Mac) 57 04-17-2018 11:22 PM
Mbox 2 not working with MacOS Sierra, help !!! Victor Bracamonte FireWire & USB Audio Interfaces (Mac) 7 08-16-2017 09:17 AM
Cedar DNS not working with Sierra gugu Post - Surround - Video 66 06-29-2017 04:00 PM
PT 12.6 HD working like a champ on Sierra plus another observation about CPU Justin1524 Pro Tools 12 14 10-25-2016 02:27 AM
Profire 2626 not working with macOS Sierra jwilkers Pro Tools 12 15 09-24-2016 09:27 AM
