Old 04-09-2012, 02:00 PM
jamesimm jamesimm is offline
Default Record/playback levels
Im getting a new issue when using punch in. Record level is great but the existing vocal track is running prior to punch the playback level is blistering..? what would cause this ? Everytime I try to punch in I have to ride the headphone levels like Balams' Ass! Am I not recording hot enough to track, or what? Im not using the headphone output on the front of the 003, Im using out put 3 & 4 on the back which you access by option/click on i/o above each channel in the mix window. Anybody got a clue?
Pro Tools LE, 002,
Focusrite Octopre, lightpipe
SPDif/2 channel
OSX 10.5.8,
S-phone multi channel headphone mixer
Old 04-09-2012, 07:48 PM
GregV GregV is offline
Default Re: Record/playback levels
This is just a wild guess, but...
If you have plug-ins on the track, like compression/limiting, that are "squashing" the signal, you can push the fader much higher while listening to the track. However, when you're recording, those plugs are bypassed which could result in the "unprocessed" playback being way too loud.
Does that make any sense?
Tracking Levels and Playback Levels paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 11-26-2010 05:37 PM
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts The Muphin Man Pro Tools SE and Essential (Win) 8 09-10-2010 07:03 PM
Record and playback levels question Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-11-2009 02:04 PM
record levels dcollison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-23-2008 12:57 PM
Creating the best mix levels / playback levels universe777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-25-2006 10:49 PM
