Re: mp3 Bounce unacceptable
All good. Well, it is almost 5am in Perth so that would make sense. @ frcjt, if you look at the pic you’ll see where to change BITRATE for an MP3. Select at least 192 (320 is better) and see if that makes any difference in your MP3 |
Indeed, my 320 mp3 bounces are nearly indistinguishable from the wave bounce. This begs the question; how are you listening to the mp3? Assuming iTunes or WMP(or similar), check the settings to make sure the program is not using some "sonic enhancement" or EQ. Also, check the on-board sound card properties for similar(my Windows rig defaulted to some awful-sounding fake surround setting)
It comes up at the maximum, 320kbit/s
cjt MacBook Pro (17-inch, Early 2011) Processor 2.3 GHz Intel Core i7 Memory 8 GB 1333 MHz DDR3 macOS HighSierra Version 10.13.6 Pro Tools 2018.12 |
This morning I am going to trash all my prefs and apply all the other optimization recommendations from Avid and see if it helps.
The point is, when I convert the WAV file outside of Pro Tools, everything is fine Thanks
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
ILOK! this is unacceptable | bacchus40 | Pro Tools 10 | 41 | 06-12-2012 02:37 PM |
LATENCY Unacceptable! Need a solution | Jj Cichon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-27-2007 10:04 PM |
Digidesign this is UNACCEPTABLE performance | the_dr38 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 04-11-2006 11:06 AM |
Unacceptable inaccuracy | Compression Records | Pro Tools TDM Systems (Mac) | 2 | 08-09-2005 11:30 PM |
Mix+ and 6.4.1 = Unacceptable plug-in count? | mikejavo | Pro Tools TDM Systems (Mac) | 6 | 09-22-2004 09:40 AM |
