mp3 Bounce unacceptable
Hi!
I am bouncing a mix of two tracks with basic EQ, Verb and Limiting. When I Bounce a WAV or AIFF everything if fine. BUT, if I try to add an mp3 or just Bounce an mp3 on its own the file is completely unacceptable. Everything is muffled and there is absolutely no clear definition. I tried doing the Bounce off-line and on-line with no difference. If, however, I take the WAV file and convert it with some other software application the mp3 if fine. Just as clear as the WAV or AIFF files. Does anyone know what's happening? How can this function be so sub-par? Pro Tools 2018.12 MBPro 17-inch, Early 2011 High Sierra 10.13.6 TASCAM US-4x4
cjt MacBook Pro (17-inch, Early 2011) Processor 2.3 GHz Intel Core i7 Memory 8 GB 1333 MHz DDR3 macOS HighSierra Version 10.13.6 Pro Tools 2018.12 |
Re: mp3 Bounce unacceptable
Muffled and garbled could describe a low bit-rate MP3. What bit-rate are you bouncing to?
You can’t choose a bit rate for mp3!
You most definitely can. Sent from my iPhone using Tapatalk |
Bit rate, not bit depth. See pic
You literally circled the option to change BITRATE, the very thing you said you can’t change.
????? FYI - you have it set to 192. Change it to 320. If it doesn’t sound almost identical to your wav export, then you have an issue that requires further investigation. Sent from my iPhone using Tapatalk |
@ Sardi, I’m not the OP. My post was to show frcjt where to select bit rate.
Whoa, slow down everybody. Let's not get confused about who the OP is.
My bad. Apologies. Sent from my iPhone using Tapatalk |
Yes. Sorry. Don’t know why I thought it was the OP. Tired eyes maybe. Hahaha... Sent from my iPhone using Tapatalk |
ILOK! this is unacceptable | bacchus40 | Pro Tools 10 | 41 | 06-12-2012 02:37 PM |
LATENCY Unacceptable! Need a solution | Jj Cichon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-27-2007 10:04 PM |
Digidesign this is UNACCEPTABLE performance | the_dr38 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 04-11-2006 11:06 AM |
Unacceptable inaccuracy | Compression Records | Pro Tools TDM Systems (Mac) | 2 | 08-09-2005 11:30 PM |
Mix+ and 6.4.1 = Unacceptable plug-in count? | mikejavo | Pro Tools TDM Systems (Mac) | 6 | 09-22-2004 09:40 AM |
