Old 11-06-2019, 04:39 AM
Default Steep breakpoint softening
This new function is good but it doesn't really avoid these short filter-sweeps when you've written hard automation changes on clip-boundaries.
What I'd actually like to see is a shortcut that will add a "handle length" to static automation so it moves the static EQ you wrote to a block of B/Gs half a second or so before the clip start and ends.
Even though AVID claims that automation is close to sample accurate, in the reality of a large session you can still hear short filter swishes when all EQ change their setting on on a clip boundary.
I'd like this to happen BEFORE the clip plays, not in a delayed way after the change which is what the new feature does.
Also just like auto-fade it relies on collaborators using the same settings otherwise your session sounds different on their rig. Which is why I NEVER use auto-fade and rely on that.
F.
PTHDn 2019.10 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 11-06-2019, 10:29 AM
thierryd thierryd is offline
Default Re: Steep breakpoint softening
somebody should give this man a cigar! ;-)
that auto-handle feature would be GREAT!
Greetings,
Thierry
http://www.a-sound.com/
Old 11-06-2019, 12:13 PM
smurfyou smurfyou is offline
One reason I've been using clip EQ for BG's. When I don't need anything fancy.
~Will
HTML code is On
set a breakpoint to 0 db oNeKOG Windows 3 10-16-2015 09:24 AM
Steep Learning Curve For Me :-) Long! ValkRider Eleven Rack 1 09-10-2013 03:01 PM
Snare Softening CosmicJunkie Tips & Tricks 15 03-31-2008 01:23 PM
Softening the Mix... How Do I do it? dounfol Tips & Tricks 10 04-10-2006 05:03 PM
'softening' guitars without killing dynamics??? JonM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-11-2005 06:45 PM
