Old 05-31-2014, 04:58 PM
2crows's Avatar
2crows 2crows is offline
Default dual monitors
hello,
i am using two video monitors, i want to put the fades on one and the edit window on the other, how do i undock the individual windows?
thanks
11rack-black star stg.60 strat-PT10.3.9
alienware : send morebrains
Old 06-01-2014, 04:22 AM
Default Re: dual monitors
Originally Posted by 2crows View Post
hello,
thanks
Do you mean you want the Edit window on one and the Mixer window on another monitor? Can't you just drag the window to whichever monitor you want it? They're not docked together. Or are you talking about moving the faders from the Edit window to another monitor? Can't do that.
Jack
QAPLA!
Old 06-01-2014, 06:53 AM
Bookerv12 Bookerv12 is offline
Mac?
Go to System Prefs.
Choose Displays.
Uncheck "mirrored".
OOOps.
I think you are on a PC.....
bookerv12
Old 06-01-2014, 02:51 PM
deanrichard deanrichard is offline
You don't. You make the Pro Tools app window full size, such that it stretches across both monitors. (You don't use the Maximize function, if you're on a PC.) Within this full size, full width window you place your Edit and Mix windows however you like, which in your case is with the Edit window on one monitor and the Mix window on the other. It sounds a bit crude, and it is, but it works well once you get used to it. I don't think about it any more, and it's fine.
hello,
thanks
Old 06-02-2014, 07:38 AM
sw rec sw rec is offline
What deanrichard said, and then close the session with alt-f4, which SHOULD store all the widow positions.
Dual monitors: Can I have my mix and edit windows on different monitors? songwritersoul Pro Tools HDX & HD Native Systems (Win) 5 05-23-2014 12:16 PM
Dual monitors and KVM? Greg B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-14-2005 10:32 PM
Dual Monitors JasonBA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-08-2004 02:09 PM
Dual Monitors JasonBA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-08-2004 07:06 AM
002 with dual monitors? scardanelli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 09-23-2002 03:35 PM
