Most Stable PTHD10 Version
I'm demoing PTHD 10 and thinking to upgrade from 9. Installed the 10.3.9 and I'm getting crazy with the input monitor bug, especially when tracking. Just like to know which is the most stable and bug free version.
Thanks
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
Re: Most Stable PTHD10 Version
I'd recommend 10.3.8. It's what we've settled back into.
While v10.3.8 is stable, you may want to use v10.3.7. There is an AAF import bug that was introduced after v10.3.7 that has yet to be fixed. Something to consider if AAFs are part of your workflow.
Thank you for the help. I've seen that someone had some issues reinstalling previous versions by doing a simple clean unistall. Do you reccomand to reformat the OS partition?
Sometimes a fresh start is the nest solution. The easiest solution is to have a backup plan. Drive imaging and cloning have save my ***** many a time
In most cases that's far more extreme than necessary. A simple uninstall should have you covered (be sure to use the one which came with the version of PT which you're uninstalling -- some folks used other versions which is why they had issues). If there's a problem after that, that's the time to try more drastic measures.
+1
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
+1
Thank you again for your input. Installed the 10.3.8 today and seen some weird things. After lunching PT my mac switches to the finder and I have to click on the PT icon into the dock to switch on PT again and for viewing PT menu. When pressing a track mute when PT is playing the signal from this track sometimes stops after a couple of seconds. When opening autotune (7) in graphic mode it's no longer possible to resize its window, sure that on the 10.3.9 it was resizable. Is anyone experiencing this?
This bug also exists 100% in 10.3.7 on two systems here. |
Most stable PT 9 and OSX 10.6 version? | allen_gibberish | macOS | 6 | 11-06-2011 04:07 PM |
Most stable OS version | OddsAre | macOS | 3 | 02-01-2011 11:44 AM |
Which PT 8 version is currently most stable? | smpkeys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-18-2010 05:15 PM |
The most stable version of PT | sphereman | Pro Tools TDM Systems (Mac) | 53 | 02-24-2007 12:01 PM |
Is the PT .5.0 stable version? | JACEK GAWLOWSKI | Pro Tools TDM Systems (Mac) | 11 | 01-19-2000 12:55 AM |
