Old 05-27-2014, 08:14 PM
EricWillhelm EricWillhelm is offline
Default Region boundaries cause waveform to return to zero
I should say, splitting a clip causes this. So yeah, just noticing that suddenly, when I split a region/clip, the waveform on the left side does a return to zero. What's up with that? And this is with 10.3.9 on Lion 10.7.5. See picture.
File Type: png Screen Shot 2014-05-27 at 10.10.57 PM.png (18.1 KB, 0 views)
Old 05-28-2014, 03:12 AM
suicune suicune is offline
Default Re: Region boundaries cause waveform to return to zero
Do you have elastic audio enabled on the track? That's the only time I've seen that happen. Or is the track in tick reference mode with a tempo change going on?
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
Old 05-28-2014, 08:13 AM
Eric Lambert's Avatar
It appears to me that the waveform at the end of the region on the right is being displayed incorrectly and that it probably continues smoothly toward zero instead of jumping upward quickly.
That said, I've also noticed that waveforms seem to round off at the ends and beginnings of regions. I haven't looked into it yet but initially thought that it might have had something to do with auto-fade being turned on. Good question though.
Old 05-28-2014, 08:25 AM
No elastic audio. No tick mode.
And Eric (Lambert), you mean the region on the left? Here's a before and after of the same spot, before and after splitting the clip.
https://dl.dropboxusercontent.com/u/5832408/before.jpg
https://dl.dropboxusercontent.com/u/5832408/after.jpg
Old 05-28-2014, 08:51 PM
Yes, my OTHER right!
If the audio doesn't click then it's just an erroneously displayed waveform - a weird bug. Annoying, but not breaking the groove.
Old 05-28-2014, 09:12 PM
Ha! (re:right)
ANd indeed, I also hope it's merely a visual glitch, and will proceed thus!
Old 05-31-2014, 07:07 AM
joachim's Avatar
joachim joachim is offline
Recalculating waveform , does that correct the visual glitch ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Expand region to maximum boundaries shortcut tvocaturo Pro Tools 10 4 12-20-2015 07:34 PM
Hotkey for return to waveform view? jschmidtiii macOS 2 03-21-2014 06:51 AM
region, yes - waveform, no? groovilator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-29-2009 08:19 AM
waveform disappearing in region harryk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-21-2008 11:44 AM
waveform not showing in region bvleugels Pro Tools TDM Systems (Mac) 1 04-27-2005 07:49 PM
