Old 06-30-2003, 06:56 PM
sonicsam sonicsam is offline
Default ProControl and second ethernet card ?
We have PT 5.1.3-AV/XL-Avid Unity + ProControl and use a second ethernet card in our G4's.
So that's one for the ProControl and one for the regular network.
Is there a sollution for the problem that you can only choose the second ethernet card for the ProControl (enet1 instead of enet0).
The answerbase said we should upgrade to 5.2 (Digistudio), but that is nowhere to be found on the Digi website... And I'm not so sure that is the right version for our setup.
Any help ?
sammy
Old 06-30-2003, 07:27 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: ProControl and second ethernet card ?
I have installed a Procontrol to a G4 MDD on its built-in network card, put a router between the ProControl and the G4. Connected to the network via the router!!!!! No second card needed, all worked well.
IMDB
Old 07-02-2003, 04:24 PM
That's great, but we still have the old non gigabit ethernet G4's... so a second card is the only option. Or should I try to connect everything via a gigabit switch ?
sammy
Old 07-05-2003, 08:08 AM
thierryd thierryd is offline
samm
AFAIK ProControl "talks" at a slow 10Mbit rate, so you don't need gigabit for this purpose. Just put a 100Mbit switch (switch is better dan hub) in between the computer and ProControl and you're fine. Other ethernet traffic will pass along.
Thierry
http://www.a-sound.com/
HTML code is On
Procontrol/Ethernet Error. Help anyone? Ru_C Pro Tools TDM Systems (Mac) 7 06-30-2008 01:49 PM
ProControl and second ethernet card ? sonicsam Tips & Tricks 1 07-03-2003 04:03 PM
Second ethernet card and ProControl ? sonicsam Pro Tools TDM Systems (Mac) 7 07-02-2003 07:19 AM
Second ethernet card and ProControl ? sonicsam ProControl, Control|24, Command|8 0 06-30-2003 06:27 AM
Using an Ethernet Zone for the ProControl John McDaniel ProControl, Control|24, Command|8 0 04-16-2000 12:18 PM
