Old 07-04-2012, 12:29 AM
RuffinMedia RuffinMedia is offline
Default Frame rate audio clip converter
Is there is a plugin IN PT that converts audio clips from:
25 to 24
25 to 23.98
25 to 23.976
Or is there an app that does it? (I prefer a plugin)
Mac Pro Quad Core - 9gb Mem - Snow Leopard 10.6.8 - Digi 002r - Focusrite Saffire Pro 24 DSP - Pro Tools 10 - CPTK - Euphonix MC Control, MC Transport and MC Mix
Old 07-04-2012, 02:57 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Re: Frame rate audio clip converter
Open a new blank session. Choose "Import session data" under the file menu.
Select tracks toy want to convert. In Sample Rate Conversion Option check the "Apply SRC" box. In sourse sample rate, from pop up menu, choose an option which is right for your need e.g 48 KHz then PAL to FILM.
A newer converted audio will be in a different pitch. You may want to use Time Shift AS plugin to change the pitch.
However there is a better way to process (or not) different stems such as music, dialogs, atmos with different algorythms or even plugins.
Search this board as this topic was covered too many times in the past.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2019.10 Ultimate ● macOS High Sierra 10.13.6
MacPro 2 x 2.4 GHz Quad-Core Intel Xeon ● 24 GB RAM
Avid HD I/O ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
Old 07-04-2012, 02:58 AM
Thats the problem. The AAF file contains correct audio and incorrect audio. Some of the audio clips are at their correct fps (24) and others are set to 25. I want to convert the audio clips that are playing at 25 fps to 24 without affecting the other audio clips (that are 24 fps).
Old 07-04-2012, 03:55 AM
mgoorevich's Avatar
That's odd. I would ask the picture editor why it happened.
But anyways. Collect all the clips 25 fps on one track and all 24 fps on other track(s).
Save session as a new one and reimport as Import session command from the older session tracks which you want to convert.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
HTML code is On
audio frame rate conversion nardo macOS 2 08-16-2012 03:47 PM
frame rate on audio file? viaspiaggia Post - Surround - Video 19 07-28-2010 01:38 PM
Audio Frame Rate NTSC to PAL mattcmi Pro Tools TDM Systems (Mac) 3 05-25-2010 01:15 PM
session frame rate converter.... colinweeks Post - Surround - Video 0 04-15-2009 09:25 AM
Free Frame Rate and Frame Calc widgets dr sound Post - Surround - Video 1 08-21-2008 12:39 PM
