#21
Re: Eleven & Logic X
I'll look at your other posts later when I've got some free time. |
#22
I'm not sure what is going on there, the red region is recording audio. Not rendering the waveform might be due to a simple problem. Once you stop recording do you see the waverform? Can you play it back (try even if you can't see anything)? Can you hear the guitar while recording? (Unfortunately with how Logic Pro X works with the Eleven Rack you may even if things are not working well). With Logic Pro X not running confirm the Eleven Rack works as a guitar processor. Try starting with a new empty Logic Pro X session. |
#23
I try to play it back and it's silent, there's no audio recorded. The waveform isn't visible after recording has stopped either. The 11r is still functioning as a guitar processor, the only issue seems to be when I try to record. Are there any screen shots that might help you better understand the issue? |
#24
Turns out I was not checking 'load default patches' under the inputs selection upon starting a new project.
works like a charm now! Thanks so much Darryl! |
#25
Somehow when I successfully record, I am unable to repeat the same steps the following day. I woke up today to continue recording only to find that once again I am not getting any signal through to logic.
I tried restarted, I checked the audio preferences to ensure the 11r is selected as the input. I checked all the same options as I did last night, but nothing is getting picked up on logic's end |
Issue with recording with Eleven Rack Patches into Logic Pro | gregoryl | Eleven Rack | 7 | 08-19-2013 07:42 AM |
Eleven Rack I/O settings with Logic | JulianMartin | Eleven Rack | 2 | 11-07-2012 02:03 PM |
Eleven Rack + Logic Pro + Lion | theoduvivier | Eleven Rack | 0 | 06-13-2012 01:15 PM |
Eleven Rack & Logic 9 - Again Basic Questions | MR290378 | Eleven Rack | 3 | 10-20-2011 10:18 AM |
Eleven Rack and Logic Pro | CoiLive | Eleven Rack | 5 | 04-15-2011 01:22 AM |
