Old 10-30-2014, 09:41 AM
simonyeah simonyeah is offline
Default Waves plugin and mouse causing CPU spikes
Hello
I am using protools hd - cptkt (10.3.8) on mac 10.8.5 and some waves v9 plugins.
When tweaking fastly waves parameters with the mouse (Renaissance eq for example but not only) I almost always ended up with CPU hits causing 6101 and 9128 errors.
When tweaking the same parameters with artist control, everything is fine.
Also, I do not even need to tweak parameter, only moving the mouse very fastly on the waves plugin parameters interface causing CPU hits.
Looks like a graphic issue I cannot understand.
Using a raedon 4870 graphic card on macro 4.1.
Anybody had experienced this or has an idea ?
Thank you very much
Simon
Old 10-31-2014, 08:15 AM
Default Re: Waves plugin and mouse causing CPU spikes
No one?
I just changed the graphic cards for a ATI Radeon HD 5770 1024 Mo.
Same problem...
Many thanks.
Old 10-31-2014, 12:49 PM
Is this mouse wired or wireless? If wireless, what happens with a wired mouse?
Old 11-03-2014, 01:39 AM
gitaifromwaves gitaifromwaves is offline
Hey Simonyeah,
I am Gitai from Waves, just came in and saw your post.
I would need some information so I can better assist you.
Did you contact Waves tech Support?
Have you tried using a wired mouse?
Are you using more than 2 monitors?
Are you using WACOM by any chance?
Let me know and I will check it out.
Old 11-03-2014, 08:57 AM
sw rec sw rec is offline
STILL haven't done anything about that "anti-multi-monitor" ploy, eh?
Old 12-19-2014, 12:06 PM
kevinbackroom kevinbackroom is offline
I've had this same issue for over a year now. Same setup. Radeon 5770, osx 10.8.5, pt hd 10.3.8. When usin most waves plugs, ssl, api ect and mousing over the plugins there are massive cpu spike which cause playback to stop. Bug is constantly repeatable. I'm really upset this is still a problem
Old 12-23-2014, 04:46 AM
Andy Gone's Avatar
Andy Gone Andy Gone is offline
Did you ask tech support? Had another graphics issue with Waves (but not with a mouse), Waves tech support sorted it out pretty fast (graphics adapter driver was a problem.
Old 12-23-2014, 06:35 PM
simon.a.billington simon.a.billington is offline
This has to be a bit of a weird bug.
I have occasionally noticed on my last machine the mouse not updating properly and "jumping" across the interface, but all is good when it goes outside the frame again. No idea if there were any spikes however, I didn't think to look.
But I do think it maybe a Radeon cars as well, will have to confirm the version.
Oh and I use the standard Mac Bluetooth mouse.
Gitaifromwaves, if you are from Waves would you be able to tell us if this may be a Radon CUDA thing??
They're constantly releasing updates for it all the time, so perhaps updating CUDA may help??
Old 12-23-2014, 08:57 PM
krazylain's Avatar
krazylain krazylain is offline
Is this one of the reasons for the screen freeze bug and CPU spikes in 11.2.2?
I use a Logitech wireless trackball and never thought it was an issue.
Studio: iMac Pro 8core 32GB | Pro Tools Ultimate, Studio One 5 | Apollo X16
Analog EQs and Compressors (SSL, Neve, Trident, Dione, Successor..)
VIs: Arturia, NI Komplete, IK, Omnisphere, UVI
Plugins: McDSP, Sonnox, Waves, Brainworx, IK, UAD
Instagram
YouTube
Old 12-23-2014, 09:38 PM
Bill Denton Bill Denton is offline
Just for my "brain bank"...
Did you have to go with the latest driver, or did you have to roll-back to a previous version.
Thanks...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Avid Pultec EQP-1 Causing cpu spikes Shifted Music AAX Plug-ins 6 08-11-2014 07:52 PM
UAD plugs via Blue Cat Patchwork causing CPU spikes. BillytheB Pro Tools 11 0 04-01-2014 07:30 PM
iLok causing CPU/disk spikes Richard901 macOS 2 10-14-2012 01:44 AM
Updated Waves Plugins causing mouse/002 issues? Longshanks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 06-10-2010 04:18 AM
NI Battery causing CPU spikes - why? timmy4402 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-30-2005 11:56 AM
