Old 04-08-2014, 09:48 AM
DAWgEAR's Avatar
DAWgEAR DAWgEAR is offline
Default Deleting playlist lanes
Is there any way to delete multiple playlist lanes in one go? I am aware of right clicking and choosing delete, but this only deletes one at a time.
Pro Tools HD Native 2020.3 | HD Omni | iMac Pro: 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Pro Tools Dock
Old 04-08-2014, 10:11 AM
mesaone mesaone is offline
Default Re: Deleting playlist lanes
Select multiples, then hold shift+alt (shift+opt) and right-click then select delete
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 04-08-2014, 05:52 PM
DAWgEAR's Avatar
mesaone,
Thanks for the response. However, I must not understand.
I am unable to select even a single playlist lane (directly in the edit window or in the track list), much less multiple playlist lanes.
I can right click on the lane name and a menu pops up, but I am not able to select the lane. Am I missing something?
Old 04-08-2014, 06:05 PM
Carl Kolchak Carl Kolchak is offline
When you click on the button (to the right of the track name, in the edit window) that gives you the options to create new playlists etc, you'll notice an option at the bottom of the menu for "delete unused".
Select that option, and a box will appear, listing every unused playlist in the session.
Highlight as many as you like, either contiguous (shift click) or non-contiguos (Command / Ctrl click) - just be sure they're one's you definitely don't want to keep - and hit delete.
EDIT :
Oops! I misread the thread title as "Deleting unused playlist lanes".
Anyway, I don't think you can delete multiple "in use" playlists at once, unless there are already alternative playlist available to all selected tracks.
You can of course select all the material in multiple tracks, and clear it all at once, which may be effectively what you're trying to achieve. Alternatively, you can delete multiple tracks at once, but that's probably not what you want.
Old 04-08-2014, 09:04 PM
DAWgEAR's Avatar
Thanks for the clarification, Carl. I was aware of what you first mentined, but that just deletes the playlist and not the lane, as you mentioned.
Once I am done comping (or have narrowed things down to 2 or 3 alternate playlists that I want to save), I tend to have several empty lanes. It looks like these no-longer-used lanes must be deleted one by one.
I tend to do this a lot so I was wondering if there was any trick I was missing. Apparently this cannot be done.
Old 04-08-2014, 09:36 PM
Gems Records Gems Records is offline
clear the audio , switch to waveform view, then back to playlist view
this clears all unused lanes
Intel i7 930 2.8ghz, dual 500gig raid 0, 1 tb audio drive, ati radeon 5560, M-Audio Projectmix io, Motu 896 HD through adat
Old 04-08-2014, 09:39 PM
DAWgEAR's Avatar
Gems Records: Brilliant! Many thanks!
Old 10-18-2016, 12:48 AM
nd nd is offline
This used to work, but it no longer seems to since I've updated to 12.6
Is there an on/off setting somewhere for this?
Old 02-01-2017, 10:22 AM
DAWgEAR's Avatar
I can confirm that this used to work but is no longer working. I have just submitted a support ticket for this. I will report back with the outcome.
Deleting multiple playlist lanes? Firechild Pro Tools TDM Systems (Mac) 10 03-31-2011 02:16 PM
Weird Bug??! 8.0.3 will not "remember" which playlist lanes are hidden! cabbagerock Pro Tools TDM Systems (Mac) 5 05-10-2010 12:21 PM
deleting takes from playlist Maddawg383 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 10-18-2009 03:16 AM
Question on new track playlist lanes in PT 8. rdolmat Pro Tools TDM Systems (Mac) 4 10-06-2008 06:33 AM
ProTools 5 deleting regions from playlist...? uno1234 Pro Tools TDM Systems (Mac) 9 06-10-2000 09:41 AM
