Old 12-22-2013, 03:27 PM
Gems Records Gems Records is offline
Default bug report-- solo playlists among grouped tracks only works if mix group is selected
When soloing playlist takes of multiple grouped tracks(ie drums)
the mix group has to be active should be the eduit group
this changed in pt11
when i"m comping drums, i sometimes alter the mix to hear certain tracks better, real pita to keep turning group on and off
to the powers that be pls notify avid
thanks
Intel i7 930 2.8ghz, dual 500gig raid 0, 1 tb audio drive, ati radeon 5560, M-Audio Projectmix io, Motu 896 HD through adat
Old 12-23-2013, 07:52 AM
Drew Mazurek's Avatar
Default Re: bug report-- solo playlists among grou[ped tracks only works if mix group is sele
thanks
Are you saying that soloing used to be part of Edit Groups and now it's not?
I think I have that right.
So this behavior is different in 11 than 10? I will try to confirm ASAP.
Off the top of my head, soloing would/should be part of Mix Grouping, not Edit Grouping. of course most people make Groups that are BOTH, since that's what PT defaults to.
www.drewmazurek.com
Old 12-25-2013, 01:16 PM
playlist soloing was always grouped as edit, because its only functuoin is for monitor comping which is editing
was this way since pt7 until pt11 broke it
even with grouped as both, the mix group must be highlighted or it wont work
definately something wrong
downloading 11.1 right now I'll post resultes later
Old 12-26-2013, 05:33 AM
I get the same behavior in 10.3.8, 11.0.3, and 11.1.
Playlist soloing works as a part of an enabled Edit Group.
www.drewmazurek.com
Old 12-26-2013, 09:21 AM
Default Re: bug report-- solo playlists among grouped tracks only works if mix group is selec
fixed in 11.1
broken in 11, 11.01, 11.02
i'm on pc , so haven't tried 11.03
Grouped Tracks Solo question teacherman Tips & Tricks 3 03-03-2011 12:36 AM
Grouped tracks changing playlists tonicjeff Pro Tools TDM Systems (Mac) 0 09-17-2009 04:25 PM
double-clicking grouped tracks removes group editingbehavior drguitar Pro Tools TDM Systems (Mac) 0 11-07-2007 10:53 AM
Possible Bug ? Tracks Grouped - No Group Selected. KingFish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-16-2005 07:55 PM
cannot group selected tracks? claudeklauss Digidesign Hardware & Software 1 02-10-2001 10:00 AM
