Old 11-18-2013, 05:36 PM
Gems Records Gems Records is offline
Default Autotune fix soon ?
Any news? still using pt10 because of the losing tracking bug.
Intel i7 930 2.8ghz, dual 500gig raid 0, 1 tb audio drive, ati radeon 5560, M-Audio Projectmix io, Motu 896 HD through adat
Old 11-20-2013, 06:56 AM
Default Re: Autotune fix soon ?
bump?
Old 11-20-2013, 09:05 AM
sw rec sw rec is offline
Talk to Antares about it?
Old 11-21-2013, 02:59 PM
chrisdee's Avatar
chrisdee chrisdee is offline
I sent them an email a couple of days ago and got an answer yesterday.
They are still working on a fix but could not say anything about how soon it will be available unfortunately.
Old 11-22-2013, 11:32 AM
dvsing dvsing is offline
I think I just ran into this bug today. AT seems to track correctly during live playback, but I did an offline bounce and found that it was applying pitch correction to the entirely wrong time index - I assume this is what you mean by "AT loses tracking". Under what conditions are you seeing this? Have you figured out any work-around? I'm in the middle of a fairly large project on PT11 so I don't have the option to revert to PT10.
I'm going to see if I can play around with it and find a work-around to keep it tracking properly. One possibility would be to do a live-bounce of the sections I use AT (it's only a note here and a note there, not pervasive), and just disable the plugin (effectively "rendering" the pitch correction).
Dan
Old 11-22-2013, 11:41 AM
Try to Audio-suite render it?
Old 12-12-2013, 11:38 PM
chrisdee's Avatar
That crashes Pro Tools 11.
Old 12-14-2013, 08:02 AM
Touchwood Studios Touchwood Studios is offline
YES PLAESE FIX AUDIOSUITE IN PT 11!
Old 12-17-2013, 04:59 PM
RyanC RyanC is offline
Same issues here...
Meta plugin does load AT7 AU (VST is VST3 so no wrapper that I know of). And it works! At live also works in meta plugin as AU.
Old 12-26-2013, 09:28 AM
was hoping 11.1 would fix autotune
no such luck
antares needs to stop dragging their feet
tried waves tune
bought it!!
HTML code is On
Autotune 4 Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 12-26-2006 07:58 PM
AutoTune 5 Cavet Your Eruptor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-15-2006 03:53 AM
Autotune 5 is out for PC mlickiss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-30-2006 07:34 AM
Autotune CRM-114 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-02-2004 07:06 PM
new to autotune...Help dheding 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-16-2003 11:11 AM
