Old 09-09-2011, 12:23 PM
T_S_Harris T_S_Harris is offline
Default ADR & VO video playback options Question
I have a video output question for ADR and VO. I'm looking to add 1 playback monitor in my studio and another one in the vox booth so the talent can see the picture. I'm running a Mac Pro with HD 2 installed. I'm looking at the Decklink Extreme. Will that give me the option to run 2 video feeds. 1 over HDMI and 1 over Composite? Any help will be great.
Tim H.
Old 09-09-2011, 12:50 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Default Re: ADR & VO video playback options Question
All the outputs are supposed to work at the same time. What i wouldn't be able to verify is if there is any different latency vis a vis HDMI / analog.
noise | jimlongo
Old 09-09-2011, 01:19 PM
Craig F Craig F is offline
plus the difference in monitors processing analog vs. digital signals
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 09-09-2011, 02:02 PM
What is another way of doing this? If the decklink isnt the right option?
Old 09-09-2011, 02:05 PM
jimlongo's Avatar
The Decklink has so many options on the breakout cable, you might consider 2 similar analog outs.
noise | jimlongo
Old 09-09-2011, 03:06 PM
a) it's best to use the same brand and model of monitor for both rooms
b) path: source output > Distribution Amplifier for the type of signal your using > to monitors (you may need extenders here depending on your setup)
this is how are ARD and Foley rooms are set up
Thank you,
Craig
Old 09-09-2011, 05:24 PM
Jim and Craig. Thanks for the ideas.
Old 09-10-2011, 09:22 AM
Chief Technician's Avatar
Post Re: ADR & VO video playback options Question
I have found that the same brand and product line/series is acceptable. You don't have to use a 50" in both your control room and the booth, but if the sizes are different, they need to be from the same product line or product series, and you need to use the same type of input. Otherwise you cannot guarantee synchronicity between the displays.
Old 09-11-2011, 12:38 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
get a mojo - cheap second hand - rock solid lock (best you can get) with avid media (guaranteed frame accurate NO drift). Composite video to both.
Your only issue then is monitor latency - measure with sync check or a dv camera - easily do-able since you have no ProTools video variable latency that you have with ALL other systems.
cheers
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
Old 09-11-2011, 07:35 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
I'm running a decklink with one HDMI and 1 composite without any issues.
5,1 Mac Pro Dual Hex Westermere 3.6Ghz, 24gig Ram, Pro Tools HD Native 2020.3.0, High Sierra, Blackmagic Decklink HD Extreme 3D.
HTML code is On
What options for video FW playback besides Canopus? zboy2854 Pro Tools TDM Systems (Mac) 0 01-21-2008 06:36 AM
Okay Video Playback Options..let's discuss DarthFader777 Post - Surround - Video 13 10-18-2007 12:59 PM
options for HD video playback on XP machine? Ken P Post - Surround - Video 13 10-29-2006 08:39 PM
playback options pre/post Question ledhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-26-2004 09:55 PM
Firewire Video Capture/Playback options? Tim R. Tips & Tricks 1 02-12-2001 10:35 PM
