Old 03-18-2010, 09:51 AM
johnnyv johnnyv is offline
Default Video question 1: DVD ripping for smoothest playback in PT
I have some DVD video that I need to rip so that I can put it into my PT session. It's concert footage of a show I'm mixing.
Can anyone suggest the best way to do this with the goal being the smoothest playback in PT when I'm running the session? I've had some files come to me in the past where the video plays really smoothly and I've had others where it really is a pain...choppy, glitchy, slow to start, etc.
Thanks so much...
Old 03-18-2010, 09:59 AM
TimNielsen TimNielsen is offline
Default Re: Video question 1: DVD ripping for smoothest playback in PT
There are many DVD ripping programs, but you'll find that most want to rip into an Inter-Frame compression scheme, like H.264, which is not ideal for ProTools. However, you could rip the DVD as a full MPEG-2 stream, so pulling the data off without recompressing it, and then use some shareware or freeware app, or maybe even Quicktime, to put it into some format that will work well with ProTools.
The suggestions seem to be to use an Intra-Frame compression scheme, such as MotionJpegA or even DV. Both of these seem to play quite smooth in ProTools.
In the past we always used MotionJpegA and had the best luck with that. Quicktime Pro on a Mac anyway can export as this format, so if nothing else you should be able to rip the DVD as whatever you can, and then convert to this.
Good luck!
Old 03-18-2010, 03:25 PM
Sean Russell Sean Russell is offline
I use MacTheRipper, but if there's no copy protection, you can just copy the Video_TS folder via Finder. Once ripped, I use DVDxDVPro to convert MPEG-2 (Video_TS folder) to a DV. It rocks.
... but does it help the chorus?
Easiest and smoothest method to stop pops, cracks World Spirit Pro Tools 10 8 03-06-2012 07:00 AM
ADR & VO video playback options Question T_S_Harris Post - Surround - Video 10 09-11-2011 09:17 AM
Video question 2: Changing video formats in session johnnyv Pro Tools TDM Systems (Mac) 1 03-18-2010 09:56 AM
switching to PC, question about video playback vudoo Pro Tools TDM Systems (Win) 2 03-28-2009 05:32 AM
Video playback question (newbie!) efisch Post - Surround - Video 3 01-30-2009 04:46 PM
