Old 02-13-2020, 08:13 AM
mixboy bob mixboy bob is offline
Default (4)S1’s with Dock setup
1st attempt to post a pic here... custom desk is under construction, but I’m loving the workflow of these now that I’m forgetting 6 years of D-Command muscle memory!!
File Type: jpg 43900B9B-7F61-4FEA-B5F0-2D57E7005798.jpg (40.8 KB, 0 views)
http://www.robburrell.com
PTHD Ultimate 2019.12/2018 Mac Mini 3.2ghz 6-core i7/32GB RAM/Aja T-Tap/Akitio Thunder 3 Quad Mini with 4TB SSD drives/Focusrite 16Line/UAD-2 Octo PCIe in Sonnet chassis/32 Channel S1/Dock with (5) 2019 Amazon Fire HD 10 Tablets/XMON//11.1.4 Dolby Atmos Setup
Old 02-13-2020, 08:53 AM
Lynn Gräber Lynn Gräber is offline
Default Re: (4)S1’s with Dock setup
This. Is. Awesome. I've got the Dock with two S1's. Do you feel its hard to reach the outside units?
Also, you finding the Amazon tablets stable? I have basically turned off EVERY service and permission on mine and feel they are finally settling in.
Old 02-13-2020, 09:12 AM
Thanks!!!
This is about 14" shorter than my 40 channel D-Command, so it feels WAY more within reach!! Haha. I barely have to lean sideways to reach the end faders without any stretch.
After I did static IP on the tablets, they have been rock solid. Maybe 1 disconnect every few days, but it usually brings itself back online within seconds and no action required on my part. I use Google WIFI, and the puck is about 9 feet from the farthest tablet, so that proximity probably helps.
Old 02-13-2020, 09:23 AM
Is your Dock magnetized on the side like the S1? Mine is not. Was a bit disappointed to find that.
You using an Amazon tablet in the dock too?
Old 02-13-2020, 09:28 AM
The dock never had magnets, so no. But my desk, when finished, will hold them right together. They sit perfectly next to each other, so unless I shove it, nothing moves.
Yes... Fire HD 10 in the dock as well! Love it....
Also, as you can see, I have the S1 tablets on mounts I built to raise them up above the S1. The viewing angle is better for my preference that way.
Old 02-13-2020, 09:33 AM
Southsidemusic's Avatar
Yep looks like a poor mans S4 or S6
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 02-13-2020, 09:38 AM
What mounts are you using? I think being able to adjust the angle of the tablets wouldve been useful. Even an aftermarket piece like the removable piece on the Dock would be awesome.
Old 02-13-2020, 09:45 AM
Yep.
Old 02-13-2020, 09:47 AM
I'll try to post a link later... client arriving soon.
I built a stand/shelf/pedestal myself, and then found some cheap $5 tablet stands on amazon that have notched angle slots, so the S1 tablets, Dock tablet, and my TC Clarity all sit at the exact same angle. Streamlines the look since it's all uniform.
Old 02-13-2020, 08:17 PM
smurfyou smurfyou is offline
Looks great!
Are you having the issue with automation dropping out after 47 seconds? That seems like a true show-stopper bug.
~Will
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Avid S1, S3, Dock and Control 0 10-01-2016 08:20 AM
OWC's TB2 dock YYR123 General Discussion 3 11-19-2014 06:39 AM
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
T20 dock??? babilonburning 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-18-2000 03:01 PM
