#21
Re: PT 8 and VISTA
while digidesign doesnīt support this, it is possible in many but not all systems. and from what i experienced, i had no difference between 3,5GB RAM 32bit and 8GB RAM 64bit. masses of vstis didnīt use more than 1,5-2GB and i canīt imagine why someone would need that many vstis. |
#22
Re: PT 8 and VISTA
I can tell you that PT in 32-bit is a VERY limiting factor for everyday work for me and many others. |
#23
Re: PT 8 and VISTA
#24
Re: PT 8 and VISTA
Pro Tools memory usage will differ greatly depending on which and how many plugins you have installed as well as the playback engine configurations and memory allocation settings. Also, you should really learn about 32-bit apps and OS ram availability, the differences between them and the architecture in general. A 32-bit application can only use around 1.5 gigs of ram even if you have more available. You can use a "largeaddressaware" patch so an application could use up to 2.5 gigs but it may not be stable and you can only do it with PT LE. The new PT 8 will use even more ram still without a possibility to use the "largeaddressaware" tweak on HD so as you can see we're inevitably getting close to running out of resources that 32-bit architecture allows for. The demands will only go up and plugins, VI's and samplers will only require more ram so 32-bit DAW's are really at the end of the lifecycle. |
#25
Re: PT 8 and VISTA
There well maybe only a few VSTi`s that are native 64 bit but the fact that most of the big ones that are velocity sample based needs definite attention Gigastudio , back then Gigasampler,(now discontinued......damn!!!) was the first dynamic velocity based sampler. It operated on a lower kernel level somehow and could load the first part of a sample and then stream the rest from disk. The Native Kontakt/Kompakt/Intakt based samplers from Best Service/East West /Zero G came next with DFD streaming. This apparently utilised a Virtual Ram Idea (correct me if I`m wrong) to buffer the first part of their metadata. I never got any of thses libraries to run as efficiently as Gigastudio. Then there is Ivory/BFD/BFD 2 not to mention the massive VSL VSTi`s,not to mention the liquid libraries. GeneOuse is totally on track when it comes to Ram usage, not to mention that the DAE loads the RTAS in a more ram intensive fashion compared to the way Steinberg loads it`s VST/VSTi`s. ( I love Pro Tools by the way, this is just one area that needs Digidesigns focus in my opinion) I dont know if it`s possible but I`m putting my vote forward for Digidesign to buy and incorporate Gigastudio from Tascam into Protools, as Tascam dont want it anymore (They have stopped developement and any support). Digi have absorbed other companies ......Gigastudio would certainly be an asset to the air arm of Digi....... |
#26
Re: PT 8 and VISTA
Vista vs. XP ... Which one is better for PT8 ? | Barbad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 01-29-2009 01:04 PM |
XP v Vista | shea | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-20-2008 11:30 AM |
Vista questions before taking the Vista Plunge | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-21-2007 08:23 AM |
LE 7.3 (XP) -> LE 7.4 Vista? | Gibb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-18-2007 04:59 AM |
Microsoft announces Vista - Vista and PTLE | myfm | Pro Tools TDM Systems (Mac) | 2 | 07-24-2005 09:15 AM |
