Mix window gone on dual monitor
Hey folks,
I just moved some sessions to a new machine, and the Mix window is no where to be found! If I choose it from the menu, nothing appears. I'm sure it's just a setting somewhere that I've missed, but if you have any quick tips, that would be awesome. Background: 1. Session came off a machine with tripple monitors 2. Moved to system with dual monitors 3. Everything plays fine 4. I can see the Edit window just fine. Thanks Jason |
Re: Mix window gone on dual monitor
Your window is still on the third monitor, at least it thinks it is. That happened to me once when I put a window on a second monitor and when I went back to a single monitor, the window was nowhere to be seen. One fix is to drag the window back to your working monitors.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Dual monitor vs single monitor setup | Whasssaaahhh | Pro Tools 9 | 23 | 03-17-2014 01:24 PM |
dual monitors... edit window + mix window | T-Jac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 37 | 04-23-2010 02:21 PM |
The window size on the Monitor | Dave Tunnell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-24-2005 10:18 AM |
Dual Monitor / hardware playback with NTSC monitor | TheBriceShow | Post - Surround - Video | 2 | 02-21-2005 05:58 PM |
Dual 1.8 vs Dual 2.0 & LCD monitor recommendations | ikon1234 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-14-2004 09:33 PM |
