Assertion error-session failure
Cannot load or rebuild manually a mix session for client this morning due to Assertion error. Submitted case to Avid.
Assertion errorCould not complete your request because Assertion in "/Volumes/Development/protools/release/2020/r3/ProTools/DirectIO/Source/CCoreAudioUtils.cpp", line 78 If anyone has info/tips to fix this, please let me know. Thank you! Mark |
Re: Assertion error-session failure
Not much info to go on
Can you open any other sessions? Have you tried holding the SHIFT key to make all plugins inactive? Can you create a blank session? If so, can you select your interface in the Setup>Hardware window? Here's something worth trying: Create a new blank session at a different sample rate(if original was at 96k, make the new session at 88.1, etc). Then try importing a few tracks at a time and select to SRC on the way in. My theory is that some minor file corruption gets "smoothed over" by the Sample Rate Conversion(it worked for me 2 times anyway). In any case, importing a few tracks at a time might reveal that its only 1 or a handful of tracks to blame.
http://duc.avid.com/showthread.php?t...ight=Assertion
just change your audio interface forth and back
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32 |
Assertion error when doing a session import | electrowerks | Pro Tools 12 | 1 | 01-23-2017 06:39 PM |
Assertion Error When Opening Session | Benot | macOS | 6 | 09-28-2015 05:00 PM |
'Neo Assertion' error while creating new session | sadistical | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-24-2007 10:56 AM |
Waves "COnyx Failure" Error when opening session? | Jeff Juliano | Pro Tools TDM Systems (Mac) | 3 | 02-23-2004 04:30 AM |
