Re: No Parameter Feedback in 11.3.1
Yes, it's a shame. EuCon can't be that complicated... It's probably the crappy EuControl software that can't handle the S3 properly.
And why is one bug fixed in a ProTools release and another similar bug will be fixed in the next EuControl release? I bought the S3 thinking it's treated by Avid like they are developing a professional tool, like the S6. (the name and ads make you think that... and the price of course) Using it now for a while it seems just like a blown up Artist Mix and is probably maintained by the same person/people that take care of the Artist series. It doesn't even have an entry in the Support Center hardware menu:
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78) LIO-8 BlackmagicDesign UltraMonitor3G Reaper 6.66, Fireface UCX MacbookPro M1Pro PTHD2021.12 MacOS12.1 BlackmagicDesign UltraMonitor3G MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB |
Thanks for pointing out the issue about the Support form missing an S3 option. I am looking into it.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
We think we have a fix for the fader issue which we are testing now. I am sorry about the frustration that has caused thus far. It's definitely not what we want your experience to be with the product. You mentioned "quite a lot of major bugs..." Will you elaborate? Thanks,
the S3 has been shipped end of November. So far we have the following major bugs: 1. Plugin Window doesn't follow the selection in channel mode 2. Faders go to sleep 3. Plugin parameter display is sometimes showing on the wrong knob. (3. got introduced with 11.3.1 which fixed the "ProTools is crashing when attentioning a track on S3 with no EQ on it." then there are the major design flaws: - touching faders when attentioning tracks - the knobs are in the way of the lower half of the upper knob displays - the touch strip is useless and I could write a long list of minor annoying things
Another small bug, I wish to power the S3 off at night (so I can cover it with a dust cover), and doing so seems to crash EuControl. (Or when it doesn't, I have to restart EuControl anyway for the surface to be recognised.)
It's good at least I don't have to restart Pro Tools, but it'd be nice to fix this.
https://lukehoward.com/ |
#16
I think that's the nature of EuCon. Once you've removed a device you have to select "restart EuCon applications" and the S3 is there again in a couple of seconds.
You don't turn off your computer at night? save some energy...
#17
I mean, you check how to control an EQ with S3: Switch a band on, switch it off, and you’ll see, that the lights on S3 do not work. Turn the freq-knob of High-Band, you see that the related display is not responding, instead of that the display of low-band is responding. Then you see that the mapping is totally weired: For example filter 1 is right to filter 2, mid-band is right to high-band. After this - as a beta-tester - I would give the feedback to development, that right now you cannot control EQ in a halfway professional sense. And when you cannot control EQ fast and intuitively, and cannot rely on the faders, how to use this unit in a mix…? - single faders stop working until restart - “In”-lights does not correspond to actual status - Parameter feedback on display is broken - EQ Plugin mapping is weired and mixed up (e.g. EQ3 and ChannelStrip) - Filter-Slope is not controllable - PT crashes when removing EQ in software - Nuendo crashes when nudging selected channels quite fast |
#18
here's another one:
the monitor section won't save the input trim settings.
#19
The parameter feedback of Surround-Panner is also broken! When adjusting the Center% the changes are displayed on the LFE-Display.
#20
Hey Kyle,
what's going on with EuControl? This was from customer support on March 9th: "Please install the latest EUCONTROL update once it is available later on this month, and let me know if there are any further issues " I already lost hope there will be any new features, but please fix the basics...
parameter assignment + artist mix | b.riesel | Artist Series | 0 | 01-21-2014 08:48 AM |
Sysex Parameter Dump | Rob0214 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-18-2008 04:41 AM |
HELP I can't open a session because "parameter... | shawnv | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-14-2004 12:09 PM |
multiple parameter changes-Mix | drenched | Pro Tools TDM Systems (Mac) | 1 | 09-04-2001 11:18 PM |
multiple parameter changes -Mix | drenched | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-04-2001 09:59 PM |
