Old 06-20-2016, 03:19 AM
mrspeaker mrspeaker is offline
Default 8.1 (or 8.2)ch surround for installation
Hi all,
I'm composing for a multi-screen, multi-channel installation that is an 8.1 config.
I want to know if in PT HD I can change the LFE channel in the 7.1 config to use as my 8th speaker channel?
Or if there are any other suggestions for spatialisation mixing I'd love to hear them. Ircam Spat looks wicked but the price tag makes my head hurt (and is still only 8ch).
There are some Max for Live patches that look ok (like XY Send Nodes), but I need to know that a.) it supports my configuration and b.) I can bounce out either a surround file, or 8 discrete channels from an automated panned session.
Would really love some help. I've been out of the game for a bit!
Any ideas?
Old 06-20-2016, 01:35 PM
reichman's Avatar
reichman reichman is offline
Default Re: 8.1 (or 8.2)ch surround for installation
The .1 channel is a full-spectrum regular channel in Pro Tools, but the panners won't let you deal with it in the way that you're thinking.
Lots of new tools out there though, so there is a way, even if requires ancillary software.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 06-21-2016, 01:46 AM
houser houser is offline
Just curious about that setup...
How are the 8 speakers physically positioned to the screen(s)?
When you say multiscreen, is it several screens with separate soundfields?
I have done some things in the past along those lines, using multiple bussing and such.
If you describe the position of the speakers and screens we might be able to give you better advice. if not, good luck regardless.
Old 06-21-2016, 07:53 AM
RecRoom RecRoom is offline
Has anyone used GRM spaces? Seems pretty well built for this type of application.
http://store.inagrm.com/en/home/15-g...ls-spaces.html
Jeff Hinton
Editor/Mixer
http://www.jeffhinton.tv
Old 11-10-2016, 03:44 AM
Thanks all for your responses. Much appreciated.
houser: to answer your question, its a circular, 4 curved screen about 21m in diameter. The speakers (8 x QSC K12s) are mounted above, 2 per screen (just coz thats the best way to evenly space them). So 1 soundfield, 4 screens. Basically a 360 immersive environment.
reichman: Thanks for that tip. I had thought there might be a chance I could pan with the LFE as the 8th channel. alas....
RecRoom: GRM! Yes - good call, I'll look into it.
In general most of the things I've looked into lead me down a path that is either waaaaaaay too much for what I need (binaural, Dolby Atmos etc) or miss the point completely (up-mixing for example).
The closest I've come is XY Nodes, a plug in Max4Live. But as yet I haven't been able to upgrade Ableton and get the M4L feature ($$$)
So annoying. I understand there may be complexity in matrixing but surely there's a simple plug out there that works across platforms and simply maps your desired sound object path to a desired speaker array.....
Old 11-10-2016, 04:51 AM
G R M SPACES!!!!
So versatile, so many options, including the exact option I WANT!!!
Haven't used it yet of course, but it looks sooo promising.
Muchos gracias
HTML code is On
Surround panning of surround tracks mik Post - Surround - Video 10 12-16-2010 09:08 PM
Ideal surround workflow with PT9 & 002 but no surround speakers? EricWillhelm Post - Surround - Video 5 11-16-2010 06:45 AM
Update only works on Installation...cannot perform installation on Win7 xRollinx Pro Tools M-Powered (Win) 5 02-12-2010 07:35 PM
SRS Circle Surround - Matrix Surround Troubles mrdale Post - Surround - Video 1 08-11-2006 02:12 PM
Anyone using Waves 360 Surround and/or Dolby Surround plug? Wheelieboy426 Pro Tools TDM Systems (Mac) 5 12-10-2002 02:13 PM
