LPK25 Not Working
So, I've read every thread here on the LPK25 midi controller and PT 11 issues (and tried the few suggestions that were offered), but it doesn't seem like any real resolution has been discovered. When I'm on the road, I like to take my LPK25 out with me. But, though PT 11 recognizes it in "midi input devices", "peripherals", and in the midi audio studio (MAC), I can't get a midi signal to be recognized in PT 11. I have midi-thru enabled, and the track is record enabled. The controller will work in Logic Pro X, but I'd much prefer to have all of my sessions in PT11.
Does anybody have ANY idea how I could get this LPK25 to work with PT11? |
Re: LPK25 Not Working
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
There's got to be some sort of simple fix for this, as PT and the LPK are both super popular products. That, or I'm in dreamland... |
So...bump?
Part IV: Playback and Recording Chapter 22: MIDI Recording Quote:
akai lpk25 connect to protools LE problems
I read all the threads and the one common thing that I can't do is set the peripheral options correctly.
I plug in the lpk 25 into my mac book air(latest OS), which is also hooked up to an avid mbox mini on another USB port, and I see the following stuff: 1) lpk plays through garage band okay 2) when I open setup/peripherals in protools it only gives me two choices none or m-audio midi BUT if I choose m-audio and fill in input with the selectable lpk25 listed, I get an error message a little later stating the protools does get the correct answer back from the m-audio keyboard. Well, its not an m-audio keyboard. 3)Note even with the message, protools DOES see the keyboard since if I configure a stereo/inst1 input port and window the midi editor the action of the keyboard generates notes and the score editor shows them. But I have no sound, and the meter on inst1 port shows no sound. The mixer widget for inst1 does not allow selecting the lpk25 as an input, and I assume this is because I cannot get it configured in the setup/peripheral window. one more odd thing: when I open the MAC midi configuration it only shows the avid mbox entry-- no lpk25. Also note if I unplug the mbox mini, to see if the lpk can play standalone into the protools LE, I get a message that protools LE won't even open without the mbox mini. So if there is a port conflict between the mini and the keyboard I can't fix it. Okay that all the gory details So what can I do other than apparently get an m-audio keyboard? Much more expensive and how do I know it will work? |
Digi 002 - optical input not working / only DI channel 1 working | Maulden7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 11-07-2013 01:46 AM |
Pro Tools 10 and Akai LPK25 Issue | jpromano78 | macOS | 0 | 05-10-2012 07:47 AM |
Protools 9 and Akai LPK25 | rawx | Pro Tools 9 | 0 | 05-26-2011 06:57 AM |
Mp3 not working and my key focus e not working | vanquished1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-02-2009 09:42 AM |
Strike 1.5 upgrade - not working because of iLok-working now | gryphondale | Virtual Instruments | 0 | 01-27-2008 09:23 AM |
