Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 03-20-2011, 07:38 PM
kayef kayef is offline
Question PT 8 not working properly with new MacBook Pro
Just got the new MacBook Pro i7 and I have problems running PT M-Powered 8 with it.
Install PT8 went fine and I'm using the M-Audio Fastrack Pro, but here are the problems I encounter:
-Launching PT works up to creating a new session. When I name it and attempt to save it I get a "PT Mpowered 8 quit unexpectedly" window every time.
I did some research on it and found a solution: PT8 is a 32bit program and the MacBook is 64bit and by pressing "3" and "2" while booting up it will switch to 32bit. This does seem to work as I can now create a session without any problems. However, all the audio in the session now have static noise present and I have a hard time believing you would really need to do this everytime you wanna run PT even if there is a fix for the static noise.
Any help would be appreciated,
Thanks!
p.s. Link to the other post http://duc.avid.com/showthread.php?t=239764
Old 03-26-2011, 03:36 PM
Default Re: PT 8 not working properly with new MacBook Pro
Problem solved and here are the details in case someone else experience the same thing.
Tried to update PT M-Powered 8 to 8.0.5 (the latest) instead of 8.0.4.
Downloaded 8.0.4 and it installed perfectly and PT launched right away.
The static noise came from the Fast Track Pro. When I switched to M-Audio 610 it was fine. I tried numerous drivers for the Fast Track but the static was still there.
Thats all!
Not working properly trife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-10-2008 08:40 AM
Start key not working properly RandyG Pro Tools TDM Systems (Win) 11 05-02-2006 06:04 AM
TC/E not working properly. twigstickley Pro Tools TDM Systems (Mac) 2 03-22-2005 10:12 AM
PT not working properly chainboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-21-2004 01:11 PM
I will pay someone to get my system working properly. CraigLearmont Pro Tools TDM Systems (Mac) 15 07-22-2002 12:55 AM
