01v (original) MIDI control of PT LE 6.4
* OS X 10.3.x
* mBoX / Pro Tools LE 6.4 * Yamaha 01v (original) * Edirol UM-2 I seem to be having a hard time getting my 01v to control (at least to begin with) the channel faders in Pro Tools. I had a good read of <http://www.soundonsound.com/sos/may0...oolsnotes.htm>, the 01v manual and the MIDI Control Surfaces guide but I'm having a little difficulty putting it all together. What I've done * MIDI hardware is connected * Audio MIDI setup : Tx Ch 1-16, MIDI Beat Clock (off), MIDI Time Code (ON) Rx Ch 16, MIDI Beat Clock (off), MIDI Time Code (ON) General MIDI (OFF) MIDI Macine Control (ON) * PT Peripheral Setup CS-10 | Tx Port (01v) | RX Port (01v) | # Channels (16) Control Surfaces Guide tells me that data is in the form BF cc vv (where cc = switch / wheel and vv is vv=value) So Fader 1 should be : BF 40 (0-7F) So I figure the last thing to do is actually set up the 01v itself - its here I get a bit lost. * Its set to Tx on Ch 16 * I set the 01v Remote (page 3) fader 1 parameters to BF 40 FAD END What the! It now works for some reason! OK, here stands an intro guide for the 01v (probably reinventing the wheel)! An afterthought - how hard is it to REVERSE things so I can control the 01v from the on screen faders? Cheers, Antony. |
Toroid Transformer for Original Control|24 | Pie Hole Sound | ProControl, Control|24, Command|8 | 9 | 08-16-2013 11:19 AM |
How to properly setup the original Mbox with the MOTU 828mkII for monitor control | confusedhelp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 06-14-2009 03:34 PM |
Mbox (original) LE 6.9.2 control problems | bree5 | MIDI | 0 | 03-10-2007 04:16 PM |
Yamaha O2R (Original) Control with HD7 | Duke Stewart | Pro Tools TDM Systems (Mac) | 3 | 12-01-2006 07:15 AM |
MIDI Import (not retaining original midi channels) | mushmouth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-14-2004 11:15 AM |
