Avid -> Pro Tools -> Avid
Having a hard time figuring this out. Thought with the newer versions of both PT an MC were more compatible.
I get an aaf and video from avid, import to pro tools and would like to send back what would be like an aaf or at least a session. I know this is odd. Believe me it's not normal. I'm not interested in sending back stems or masters, but lot's of cuts, regions and maybe some plugins (digi stuff only) It was my estimation that later versions of these apps brought the ability to speak the same language and work together in a tighter collaboration. Any help on this?
NuanceTone.com |
Re: Avid -> Pro Tools -> Avid
Several probs:
New media will get made at both ends most of the time due to either embedding media or padding to frame boundaries making relinking broken More importantly the features have been put into mc to export more stuff in the aaf but no such features have been put in the digitranslator code on the pt side. Last i heard even volume auto didnt get put into pt exported aafs. Let alone plugins panning or automation. Easy enough to test on the pt side. |
Nope, nothing gets through except channel order and width of tracks and clips.
MC uses a different signal flow. RTAS plugins do translate from MC to PT (assuming they are installed) but are pretty much useless due to the different signal flow. There currently is no really effective way of sending stuff back to MC without losing info unless you send bounces/stems. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Out of curiosity, what happens to (PT) edits that don't fall on (MC) frame boundaries? Do they get extended, shortened, or moved to the nearest?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM Over 30yrs experience in pro-audio - mostly for picture. |
PT creates new media on export, so the edit can be where you made it.
Sorry, if that answer's my question, I don't understand the answer:
In MC, the editor puts an hard cut at 10:01:02:03 In PT, I move it a quarter of a frame later to 10:01:02:03.25 When it goes back into MC as an AAF, where is the cut?
The MC will have thousands of tiny dummy-clips in the timeline that fill up the space to the nearest full frame.
Can Avid HEAT run in PTHD 10/11 without an Avid Audio Interface or HDX Card? | hatepop | Pro Tools 11 | 1 | 12-19-2013 01:26 AM |
Unable to locate Avid hardware. Avid Pro Tools SE 8.0.3 (M-Audio KeyStudio 49) | azndisast3r | Pro Tools SE and Essential (Win) | 3 | 09-21-2013 02:31 PM |
FS: (EU) Avid HD3 PCIE , 2x Apogee DA16X + X-HD, Avid Digilink & AES/EBU Cables | Eduardo Apolonia | Buy & Sell | 12 | 03-20-2013 04:42 PM |
Will (Avid/M-Audio) Pro Tools MP 9 support Avid Vocal Studio: Producer USB Microphone | XDosShane | Windows | 0 | 02-04-2012 09:17 PM |
AVID Website | Pros & Cons | Dedicated to the AVID Web Crew | 25ghosts | Pro Tools TDM Systems (Mac) | 10 | 07-28-2010 08:49 PM |
