best D/A solutions
Im running 8.0.1 LE and I need 16 channels of A/D conversion, who has been through this and found the solution? Avalon? (not cheap) 96i,? or a DAW console? let me know your thoughts and ideas.......
Older Mac G5 dual core OS Leopard LE 8.0.1 24 channel analogue mixer with inserts need some advice |
Re: best D/A solutions
for 8 a 002/003 with some other 8 channel ADC with ADAT Lightpipe out is your only method
the Beringher unit seems to be the best budget option for the extra 8 ADC
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Might want to change the subject line to "A/D". Slightly different bucket of fish, since there might be different types of solutions involving mic-pre's.
You can't use the 96i with your LE system. It's HD only. Plus no support even for HD starting in the next software revision. Depending on your budget, you might want to keep an eye out for the previous generation of Apogee AD16's (pre-x series, solid purple front). Certainly can be had cheaper than the current generation and sound great/work just fine if you feed them clock. Is the Apogee Ensemble out of your range? I don't know the Avalon unit. I had a 96, and the Apogees were a step up, more similar to 192 quality, possibly a little better. So I can recommend any Apogee solution that does 24/96. I don't know your needs entirely. I still run everything 24-44.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
Drive Solutions for G5 | CHRIS AIKEN | Pro Tools TDM Systems (Mac) | 4 | 11-20-2007 04:17 PM |
Mic Pre solutions? | stuie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-16-2007 06:27 PM |
Backup Solutions? | Nashville Bass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-06-2002 05:13 AM |
PT5.1.1 need some solutions | PiratePost | Pro Tools TDM Systems (Mac) | 0 | 08-03-2001 01:45 PM |
PT5.1.1 need some solutions | PiratePost | Pro Tools TDM Systems (Mac) | 0 | 08-03-2001 10:18 AM |
