How to insert / delete time
Hi guys,
I know Nuendo has this feature and I run into the need last week when I'm doing editing for a Christmas play. I need to insert or remove a couple of seconds here and there and I want all the clips from that time forward to move up / back accordingly together. Moving those regions using the grabber is cumbersome. Is there an insert / delete time feature in PT 5.3 ? |
Re: How to insert / delete time
group all the tracks and nudge your reasons to insert & delete time.
getting the hang of slip/shuffle modes will help with this kind of thing too. |
In a nutshell:
1. Turn on the all group. 2. In shuffle mode, select the location and duration where you would like to insert/delete time. 3. Press delete to delete time, or use the "insert silence" command to insert time. Voila! -Eric |
Awesome guys ...
thanks a million. - Haniel Quote:
I'm a recent convert from MOTU/DP and am trying to insert a couple measures into a song. In DP, you just did an "insert measure" command and everything moved, including markers.
In PT 6.1, when I do the "insert silence" command, following the directions described below, everything moves except the memory location markers. Does anybody know how to insert measures or time (or "silence") as Digi calls it, and have the memory locations move right along with all the MIDI, audio, etc? Thanks very much. > 1. Turn on the all group. > 2. In shuffle mode, select the location and duration where you would like to insert/delete time. > 3. Press delete to delete time, or use the "insert silence" command to insert time. |
At the moment this can not be done in Protools, and it is one of most important thing that still is missing (along plugin delay compensation)
The mentioned workarounds are great and work, as long as you don't have markers, complex tempo/bar change information and playlists. But if you have a organized song with markers and things up their, it is horror. Even worse, with the workarounds mentioned only the top playlists are shuffeled. What if you have a project where as different edits are on playlists? There is absolutly no way to "insert/delete" time now. (Unless you want to do it for all playlists seperatly). No way, but this is a really important feature that is missing for years, and it is somthing where the workarounds really do not work in many situations. daniel |
If you shift + click in the Marker and tempo timeline when copying and pasting, then the Markers and tempo events, etc. will also be edited with the audio.
Rail
daniel |
> then the Markers and tempo events, etc. will also be edited with the audio. True, but this doesn't solve the problem. The problem is that when you insert time, the markers that follow the insertion point do not move. I.e, if a marker called VERSE 1 is placed at measure 10, and then I "insert" two measures before measure 1, then VERSE 1 marker should move to measure 12 and it doesn't (in PT 6.1). |
Rail
How to delete blocks of time in PT?? | Kaotic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-13-2012 10:28 AM |
Insert or delete space | bookwrm | Pro Tools M-Powered (Mac) | 2 | 06-25-2009 02:30 PM |
Delete key and Time Shift Plugin | Matthew Steel | Pro Tools TDM Systems (Mac) | 2 | 02-24-2007 02:40 AM |
How to delete audio, or time across all playlists? | Kris | Tips & Tricks | 4 | 11-21-2003 07:12 AM |
How to insert time / insert measures, without upsetting tempo map and markers | imp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-25-2003 05:45 PM |
