pro fire 2626
Hello,
i'm new to mpowered & mac together & i just got my new system today btw.....i've had mpowered on a windows system for a few years now. anyway here's my problem. i'm plugged into the profire 2626 input 1 thru Gearbox D.I out. i've got the plugin running on a crunch setting. the deal is that i can still hear clean guitar coming thru my speakers along with the plugin. i'm sure it's a routing thing but i can't figure it out.....help please?!! thanx in advance. profire 2626 imac core 2 duo 2.4GH |
Re: pro fire 2626
Newbie myself, but here's a couple of checkpoints -
1. Check the Output settings in your Mix window (e.g. it should be OUT 1-2 if you are monitoring via a your stereo outs). Make sure you are not outputting to a Bus 1-2 or somesuch. 2. Check the input settings (should be your guitar input that you are plugged into on the pro fire, also as named in Setup -> Peripherals/I/O...) 3. Do you get the same clean guitar without firing up Pro Tools? Trying to see if your interface is not correctly routed/setup in PT for some reason. 4. Are you using an Audio track or Aux or something else?
Mac Pro OS X 10.5.3 8-core Quad Xeon 5400 @ 2.8GHz 10GB RAM Pro Tools M-Powered 7.4.2 ProjectMix I/O Version 1.3.2 Driver 1.8.4 Build 3 OWC Elite-AL (on FW400 as is PMIX) |
Re: pro fire 2626
hey thanx for the reply....what i ended up doing is just muting the 1st channel on the mixer for the profire & it works fine now. thanx again very much.
Re: pro fire 2626
In the "Router" section of the 2626 control panel, if you have Analog Out 1/2 set to Mixer Out, you'll hear the output of Pro Tools and ANY of your inputs into the 2626. Which means if you have a mic or guitar, you're going to hear double of it (with zero latency) unless you mute that channel in Mixer (like you've already discovered) or you can change Analog Out 1/2 to be Software Returns 1/2. This will give you consistent monitoring without having to change any settings, however, you won't get zero latency monitoring.
Re: pro fire 2626
Hi, I've recently purchased the profire 2626 to go with my newly installed m-powered pro tools. I upgraded to 7.4 and then read that I needed 7.4cs7 to work accordingly with the 2626. I believe i did this? however, when I power it up it only reads 7.4. Should it read 7.4cs7? I started with 7.0 then 7.3 then 7.4 then 7.4cs7. Do I need to uninstall any of these?
The problem is when booting up it either says it can't detect my interface to check to see if it's plugged in or turned on OR it says my ilok authorization number can't be found.? Again, I believe I have down loaded the appropriate drivers, upgrades and authorizations to be up and running. I also feel like I've been doing circles and at this point I'm completely confused. Was on hold for Digi for 30min. and never got through. Can anyone help? thanks alot! -seth |
Re: pro fire 2626
1. Create and Aux Input 2. create a new Audio Track 3. Set the input of the "Aux Input" to the corresponding input on the 2626. 4. Set the output of "Aux Input" to Bus 1 5. Set the input of your new "Audio Track" to "Bus 1". 6. Set the output of "Audio Track" to whatever your master out is probably 1-2. 7. Place your "crunch" plug-in on the "Aux Input". I see you already muted channel 1. You really shouldnt have to do that...Not sure why in this case. My Profire is set up the same way. |
Re: pro fire 2626
Are you able to get the M-Audio mixer software to load?? I believe there is a new version of the Ilok software. I had to update mine last week to transfer a licsense. Try re-installing the latest M-audio drivers as well...this fixed a few issues I was having initially. |
Re: pro fire 2626
I'm using OS 10.4.11.
I'll try updating drivers and check out new ilok updates. thanks, -seth |
Re: pro fire 2626
and yes the m-audio mixer does load.
? thanks, -seth |
Re: pro fire 2626
Have you tried reinstalling the 2626 drivers? Actually you should do an uninstall, then reinstall.
Did you previously have any other M-Audio hardware drivers installed on this machine? If so, you should uninstall those as well, before installing the 2626 driver. When you're being asked about the iLok - what does the message say, exactly? See the Help Us Help You thread for more info on what we need to know to help you properly. |
Pro Fire 2626 Clock issue maybe?? | necjamc | Windows | 3 | 12-18-2012 08:07 PM |
connect Focusrite Pro 40 and M Audio Pro fire 2626 | Lance Smith | Pro Tools 10 | 0 | 04-20-2012 02:29 PM |
pro fire 2626 and pro tools 9 le | billpeters1967 | Pro Tools M-Powered (Mac) | 1 | 06-30-2011 08:39 AM |
ProFire Lightbridge / Project Mix IO / Pro Fire 2626 | doppler58 | Pro Tools M-Powered (Mac) | 4 | 09-02-2010 11:49 AM |
Pro Fire 2626 seems to be having problems. | Alex Stolichnya | Pro Tools M-Powered (Mac) | 7 | 04-16-2008 03:10 PM |
