using d-verb for singing
does anybody know how to use d-verb to make it sound like you can sing what are the best input, mix,algorithm,size,diffusion,delay,pre-delay,hf cut,lp filter settings for it or any advice and help is usefull thanks!
Re: using d-verb for singing
HI,
welcome aboard, you can get cozy with how reverbs work here: http://www.theprojectstudiohandbook.com/articles5.htm regs
last: PT11.3.1 |
Holy cow! Thanks for the link, good read. I´ve been recording for 30 years one way or another. Digital came with Atari Falcon. Still learning.
-------------------------------------------------------------------- - i7 520 @ 3.6 GHz / P6T / XP32 / PTLE 8.01 . PT9 on Snow . - PTLE8 on a macbook. - And a bunch of miscellaneous obsolete hardware from the past. Like Mix ++++ 64 i/o with Control/24 I`m In The Band: www.ozofficial.com My guitars are in tune : http://www.truetemperament.com/site/index.php |
can somebody tell me the levels they set there d-verb at for singing thanks!
The settings that are used really just depend on the vocalist and song. Generally, having a Plate reverb sounds the best with vocals. The decay, pre-delay, mix, and etc. just all depends on the song. Normally you want to time the reverb to decay in time with song. Just use your ears and play around with it.
Eric PT M-Powered 7.3 |
C-
Reverb does not do what you are expecting it to do. . .
Re: C-
thats not what i heard, everybody i asked "what effect makes you sound like you can sing",and they all told me reverb
Re: C-
Reverb just adds realism (or exaggerated "realism" heh) to what you have. If you can't sing, it won't make you sound like you can. It'll just make it sound like you're in a "real" environment.
Re: C-
the "effect" that makes you "sound like you can sing" is called a good voice.
Reverb makes bad singers sound like bad singers drenched in reverb.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Re: C-
well GOOD 4 U,na just playin thanks for the help,appreciate it
Bad singing | Ian Palmer | General Discussion | 4 | 10-30-2008 08:44 AM |
Singing Options | Inneed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-01-2005 05:47 PM |
Singing Underwater? | Ted Blaisdell | General Discussion | 3 | 12-12-2002 11:38 AM |
No singing necessary! | snapple | General Discussion | 0 | 05-15-2002 08:26 PM |
I'm singing the s/pdf blues..... | Joe Ninowski | General Discussion | 0 | 09-02-1998 09:20 PM |
