Import Session Data problem
Why is it that when I go to import session data, the "refer to audio media" is greyed out and I can only copy? I don't want another copy of the damned audio! It's sitting right there in the correct format/sample rate!
Re: Import Session Data problem
Usually this indicates that the target session is set differently from the audio you're importing. Such as: Your session is 24-bit but the audio is 16-bit, or the session is .sd2 and the audio is .aif.
Or at least ProTools thinks this is the case.
Anyone who isn't confused, really doesn't understand the situation. |
Import session data problem - out_of_range | cppmusic | Pro Tools TDM Systems (Mac) | 15 | 10-12-2010 10:18 AM |
Import Session Data Problem...? | Nathan W. | Pro Tools TDM Systems (Mac) | 3 | 08-31-2009 03:24 PM |
Problem with Import Session Data in ProTools 8 | Corto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-16-2009 04:35 PM |
Problem with import session data 7.1cs9? | Jon_Atkinson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-17-2006 08:08 AM |
Import Session Data Problem | Rawbs | General Discussion | 1 | 11-10-2005 02:06 AM |
